Don’t Let The Pressure Get To You – Trust Contrinex Pressure ️ Rated Inductive Sensors – www.Pressure.PLUSAx.co.uk
Tuesday 10 May 2022, 12:54:11 PM
Contrinex HIGH-Pressure rated Inductive sensors can operate at a peak pressure of 1,000 bar and sense at up to 3mm, ensuring reliable, accurate sensing in the most demanding pneumatic and hydraulic applications, and offer 50 times longer lifetime under pressure than the industry standard.
Contrinex’s remarkable HIGH-Pressure inductive sensors are suitable for continuous duty at pressures up to 500 bar (7,250 PSI) and peak pressures of 1,000 bar (14,500 PSI). They ensure reliable, accurate sensing in the most demanding pneumatic and hydraulic applications and are available with classic metal housings or one-piece, stainless-steel construction.
The HIGH-Pressure inductive range is ideal for detecting the smallest parts and are ideal for piston-control applications where space is at a premium, with world-class reliability.
PRODUCT ADVANTAGES
HIGH PRESSURE – Continuous pressure range up to 500 bar & 1,000 bar peak, 50 times longer lifetime under pressure than the market standard, Long sensing ranges up to 3mm, Exceptional reliability in miniature packages, Mechanically and chemically rugged, Gas-tight sensing face, ️ Operating temperatures up to 100°C, ️ IO-Link – Ideal for Industry 4 and offering Plug and Play swap-out.
No alt text provided for this image
Contrinex also offers EXTRA-Pressure inductive sensors for lower pressure application, with the benefit of low-pricing. These sensors offer dependable, accurate presence- and position-sensing at pressures up to 200 bar. The ideal solution for position and presence sensing where pressure would damage a normal inductive sensor, they benefit from world-class performance and build quality.
Contrinex EXTRA-Pressure inductive sensors excel at operating continuously in permanently pressurised conditions and at water depths up to 1,000 meters. The combination of a stainless-steel housing and a permanently bonded ceramic or sapphire-glass sensing face guarantees robustness and exceptional reliability in miniature packages sized from ø3 to M8.
PRODUCT ADVANTAGES
️ EXTRA PRESSURE – Extended pressure range up to 200 bar, Long sensing ranges up to 2.5mm, Exceptional reliability in miniature packages as small as ø3mm, ️ Suitable for high vacuum applications, Gas-tight sensing face, Mechanically and chemically rugged, Highly Reliable with Long Service Life, Excellent price-performance ratio, ️ IO-Link – Ideal for Industry 4 and offering Plug and Play swap-out.
Read more on the Product Page, Click to download the Product flyer, or Click to download Contrinex’s Product Overview brochure to find out more.
PLUS Automation Ltd is the importer of Contrinex sensors into the UK and Ireland, and can help you #MakeSenseofSensors to solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional Inductive , Photoelectric , Ultrasonic , RFID & Machine Safety sensors.
