Contrinex Inductives Help ️ ️‍♂‍ ‘Jack it Up!’
Tuesday 24 November 2020, 6:30:28 AM
Contrinex Inductives ️ ️‍♂️ ‘Jack it Up!’ to Help Bridge Construction
Modern road bridges are typically constructed using mobile cranes to lift prefabricated bridge beam onto support columns. Heavy-duty hydraulic cylinder jacks support the ends of each bridge section to enable accurate height adjustment prior to final positioning. Engineers require rugged sensor systems that detect the position of each cylinder accurately.
These sensors need to be mechanically robust and must withstand harsh outdoors conditions. – Read more at 500.PLUSAx.co.uk
CUSTOMER APPLICATION
A specialist lifting company uses heavy-duty hydraulic cylinder-jacks to position prefabricated bridge sections during roadway construction. A bridge single section requires up to 20 jacks for accurate positioning, with each jack having a capacity up to 1,000 tons with a stroke up to 30mm (1.25 in). On-site conditions are harsh with cylinders exposed to water, mud and dirt, and may also be subject to mechanical shock and vibration.
The company requires rugged sensors that operate reliably and accurately in the demanding environment. Historically, engineers checked the position of each cylinder manually; this was both time-consuming and subject to human error. Previously trialled sensors were insufficiently robust, necessitating frequent adjustment or replacement, and had inadequate sensing distances.
A simple, contactless system must provide fit-and-forget operation with extended maintenance intervals. The sensors need to be mechanically robust and must withstand prolonged exposure to the harsh outdoor conditions of a construction site. An industry-standard interface is highly desirable to avoid the need for specialised control systems.
CUSTOMER SOLUTION
Rugged Extra-Distance inductive sensors from Contrinex 500 Series are ideal for this application. Highly reliable and rated to IP67, these units are robust and accurate. A one-piece M30-diameter chrome-plated brass body with PBTP sensing face and vacuum-encapsulated electronics make this device well suited to the hostile environment, and the sensing distance of 22mm allows fully contactless operation.
On each jack, a single sensor is fitted on a metal bracket that is welded to the side of the cylinder; a bearing plate, mounted on the end of the ram, distributes the load onto the bridge section. During operation, the ram extends, lifting the section; when it reaches the desired height, the sensor detects the position of a small metal target mounted on the bearing plate, halting the ram.
The sensor is configured with an industry-standard PNP normally-open interface, and connection to the jack’s hydraulic control system is via an integral M12 connector and PVC-sheathed cable; this allows easy removal and replacement during routine maintenance. The sensor is impervious to water ingress, mud and dirt; reliability has been excellent. Contrinex inductive sensors deliver a cost-effective solution that satisfies the customer’s requirements for a simple, fit-and-forget system.
PLUS Automation aims to help you #MakeSenseofSensors, helping solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional choice of sensors. Find more information and read other application examples go to www.PLUSAx.co.uk
PRODUCT ADVANTAGES
Reliable & fast detection
22mm sensing range
Robust & reliable in demanding conditions
IO-Link – Ideal for Industry 4
️ -25°C to +70°C
Low-cost solution
FIND OUT MORE
Find out more at 500.PLUSAx.co.uk, or Click to download a flyer, or Click to download Contrinex’s Product Overview brochure
PLUS Automation aims to help you #MAKESENSEOFSENSORShelping solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional choice of sensors.
