Application – Photoelectrics ‘get a grip’ of Shipping Containers
Tuesday 27 October 2020, 7:30:44 AM
Contrinex’s C23PA photoelectric sensors help ‘get a grip’ of shipping containers at a busy container port. Find out more at http://C23PA.PLUSAx.co.uk
At busy container seaports, purpose-designed container-handling vehicles called Straddle Carriers, operate around the clock, loading, unloading and stacking containers. Space utilisation is increasingly important and correctly identifying the size of container picked for each lift is essential for efficiency.
Contrinex photoelectric sensors have been fitted to the Straddle Carriers to detect the container size and eliminate the need for drivers to carry out identification checks, saving time and avoiding errors.
CUSTOMER APPLICATION
Contrinex C23PA photoelectric sensor on a saddle carrier
A fleet of straddle carriers, purpose-designed container-handling vehicles, services a busy container port. As a straddle carrier moves over a container, a central lifting beam lowers and locks onto the corner castings of the container; each lift comprises either a single 40-foot container or two 20-foot containers.
Optimal utilisation of storage space is essential; correctly identifying the size of container picked for each lift is vital. Fitting carriers with sensors that detect the size and type of containers at the time of lifting eliminate the need for drivers to carry out identification checks, saving time and avoiding errors.
The original mechanical sensors proved unreliable, losing calibration when subjected to continuous vibration during normal operation. Although the scheduled maintenance interval for each vehicle is 1,000 hours, mechanical sensors required recalibration at intervals of no more than two or three days. A highly stable replacement sensor system was required.
CUSTOMER SOLUTION
Contrinex C23PA photoelectric sensor - Close up on Saddle Carrier
Highly stable and reliable, the C23PA photoelectric sensors from Contrinex provide a reliable and cost-effective solution. The moulded-resin sensor casings, fitted with coated-plastic sensing faces, are IP67 rated, making them virtually impervious to the harsh, salt-laden environment of a busy container port. Connection to the vehicle’s control systems is via an integral M12 connector and PVC-sheathed cable, allowing easy removal and replacement during routine maintenance.
To confirm the size of the container, two pairs of diffuse sensors with background suppression are mounted centrally on each lifting beam. As the lifting beam descends, one sensor from each pair detects the presence or absence of corner castings at the central lifting points, while the other detects the presence or absence of the gap between two 20-foot containers. The combination of the two eliminates incorrect identification in the unlikely event that the first sensor returns a false-positive signal from a 40-foot container.
A physically small housing and long sensing distances eliminate the risk of accidental damage arising from a mechanical collision, while rugged industry-standard housings and vacuum-encapsulated electronics minimise the effects of vibration.
Operational results have been excellent; the new Contrinex sensors have eliminated calibration errors and reduced maintenance costs significantly.
PRODUCT ADVANTAGES
Long sensing range – Up to 500mm
Small sensor – 30mm x 20mm x 10mm
Exceptional resistance to extreme vibration during operation.
️IO-Link– Ideal for Industry 4
Reliable, repeatable sensing performance in demanding operating conditions
️Low-cost metal mounting brackets and protective sleeves
Simple to implement & cost-effective
FIND OUT MORE
PLUS Automation aims to help  you #MAKESENSEOFSENSORShelping solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional choice of sensors. Find more information and read other application examples go to www.PLUSAx.co.uk
Click to download a flyer to find out more about the sensors, or Click to download Contrinex’s Product Overview brochure
