Application – Analogue Inductives ‘get the measure’ of Textiles
Thursday 22 October 2020, 6:25:00 AM
Contrinex’s Analogue Inductives ‘get the measure’ of Textiles
Contrinex’s precision Analogue output inductive sensors are used on an almost unimaginable array of applications and industries, and one example is a specialised textile-testing machine where it measures the thickness of a moving textile web at a high-speed – http://Analogue.PLUSAx.co.uk
As the web passes over a roller, the analogue inductive sensor, positioned directly above the roller, rests lightly on the top of the web. Sensing the distance through the material to the roller, it precisely measures the thickness of the material.
CUSTOMER APPLICATION
Contrinex analogue inductive sensor on textiles measurement machineapplicationFor the efficient manufacture of textiles and fabrics, the thickness of material needs to be measured immediately after its formation to enable real-time adjustment of the production process. Therefore, a manufacturer of specialised textile-testing machines uses a high-accuracy sensor to measure the thickness of a continuously produced sheet, or web of the material moving at up to 5m/s (16.4fps).
Measurements are required across the full width of the textile web, which can be up to 4 metres (13ft) wide. To achieve this a sensing head is mounted on a transverse-axis carriage which lies immediately above a fixed roller, traversing the width of the web as it passes over the roller. In this application, the precision sensor is providing real-time measurements in the range 0 to 4mm with a resolution of 0.02mm (0.0008”) or better.
High-frequency measurement is provided to accommodate the speed and width of the moving web. A continuous analogue output is necessary as conventional digital sensors do not provide the required resolution.
CUSTOMER SOLUTION
Closeup of Contrinex analogue inductive sensor on textiles measurement machine
Contrinex’s Analogue Output Inductive sensors are highly accurate and provide the continuous voltage or current outputs required for this application. The quasi-embeddable sensors feature a chrome-plated brass body and PBTP sensing face, with the M18-diameter sensor allowing sensing distances up to 10mm (0.4”) with resolution in the µm range.
The sensor, mounted in the sensing head, moves rapidly back and forth across the web and senses through the material of the web as it feeds over the roller. It measures the distance from its sensing face – which lies a known distance from the bottom face of the head, to the top surface of the roller. It delivers a precisely calibrated, near-linear, discrete output in the range 0 to 10V or 4 to 20mA.
The Contrinex inductive sensor has a sealed cable entry, ensuring fit-and-forget capability during extended periods of operation, and connects with the machine’s control system via a flexible PUR-sheathed cable. Using a custom-configured software interface, output data is displayed numerically and graphically on a screen, allowing real-time adjustment to the production process when necessary.
Contrinex’s Analogue Output sensors provide a cost-effective solution that satisfies the customer’s requirements for accurate high-speed measurement with an exceptional resolution.
PRODUCT ADVANTAGES
Contrinex analogue inductive sensor Continuous measurement with current or voltage analogue signal
Precisely calibrated, near-linear output
High-speed measurement with an exceptional resolution (µM)
Best-in-class temperature stability
Long sensing range – Up to 40mm
Highly reliable, cost-effective solution
FIND OUT MORE
Contrinex analogue inductive sensor brochure
PLUS Automation aims to help you #MAKESENSEOFSENSORS, helping solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional choice of sensors. Find more information and read other application examples go to www.PLUSAx.co.uk
Click to download a flyer to find out more about the sensors, or Click to download Contrinex’s Product Overview brochure
