Edge Technologies Introduces Magazine Feeder Bar
Tuesday 12 July 2022, 9:58:54 AM
The Commander 8-80 from Edge Technologies is a compact, magazine-style bar feeder that features an 8-80-mm bar diameter capacity range for feeding 12″ and 6″ length round, square, hexagonal and shaped bar stock into fixed headstock CNC lathes. With a large magazine capacity enabling for unattended operation, the Commander 8-80 offers the advantage of automatic bar loading with a small footprint.
The loading storage capacity is 406 mm (16.0″) deep. Bars are loaded from the front of the bar feeder. Large diameter bars are lowered into the channel area with a “soft-load” device. Material is then guided into the lathe within urethane channels, eliminating the potential for marring of the bars’ surfaces. Bar stock with lengths up to 3,800 mm (12′-6″) can be loaded by the Commander 8-80. With the newly designed oil-filled channel sets, changeovers are completed within minutes and allow for quiet operation, according to Edge Technologies. The main beam and support stands are designed to be resistant to flex, enabling vibration from bent bars to be at a minimum. An oversized front steady claims to eliminate harmonics as the material is transferred from the bar feeder to the lathe.
The Commander 8-80 features a 7.0″ touch screen control with a 500-part program storage. A hand-held controller is standard for making setups and changeovers effortless. The newly updated electronic package comes with Ethernet I/P support. Some additional features are feeding to a stop or position and operation with subspindle mode.
This news article comes from mmsonline.com
