DePe Gear Company Powers Up with DN Solutions PUMA 5100LM for Large Precision Turning
Sunday 22 June 2025, 4:35:28 PM
Precision gear manufacturer DePe Gear Company, based in Stoke-on-Trent, Staffordshire, has expanded its machining capabilities with the installation of a DN Solutions PUMA 5100LM – a heavy-duty turning centre designed to handle large, high-precision components with ease.
Specialising in the production of gears, shafts, and power transmission components, DePe serves a wide range of demanding industries including rail, defence, power generation, marine, and off-highway sectors. The company frequently machines complex parts in tough materials, many with diameters up to 650 mm and lengths up to 2 metres — the exact kind of work the PUMA 5100LM was built for.
A Perfect Fit for Large, Complex Work
The PUMA 5100LM from DN Solutions is a horizontal turning centre designed for exactly these kinds of applications. With:
  • Maximum turning diameter of 650 mm
  • Turning length up to 2000 mm
  • Box guideway construction for stability and rigidity
  • Live tooling (M spec) and long-bed (L spec) for flexibility
…it provides the power, precision, and reliability needed for large component machining in a single setup. This means fewer operations, shorter cycle times, and more consistent part quality — all vital for industries that demand high accuracy and fast turnaround.
Backed by Mills CNC in the UK
DN Solutions (formerly Doosan Machine Tools) is a global leader in CNC technology, offering a wide range of turning and machining centres for manufacturers around the world. In the UK, these machines are supplied and supported by Mills CNC, one of the country’s most respected machine tool distributors.
Mills CNC not only supplies the machines, but also provides comprehensive applications support, operator training, and ongoing service — giving UK manufacturers like DePe the confidence to invest in high-performance equipment with full backup.
Ready for the Next Level
With the new machine now fully operational, DePe Gear Company is well-positioned to take on even more complex and large-scale projects. Their investment in the PUMA 5100LM demonstrates a clear commitment to continuous improvement, technology adoption, and supporting the UK’s heavy engineering sector with quality and capacity.
📹 DN Solutions recently shared footage of the machine in action, turning a large component — and it’s a clear example of how this platform enables top-tier performance when it matters most.
