But How Does The Chick OneLOK Actually Eliminate Long Set-Up Times?
In the latest MTD Technical Corner, Gio is joined by Richard Evans from 1st MTA and they technically review the Chick OneLOK Workholding Solution.
Re-engineered from the ground up for vertical milling machines running fewer than 20 parts, the OneLOK’s design captures dramatic improvements in speed, precision and versatility.
Setup Quicker The BoltFast™ jaw system shaves valuable time off jaw changes. One simple screw turn provides fast precise repeatability. Stop wrestling with buried screws, stop re-cutting jaws, and start saving time.
Operate Easier Designed with the machinist in mind. At nearly half the weight of 1950 style vices and with an ergonomic handgrip, the OneLOK can be handled with ease.
Work Cleaner OneLOK’s sealed design eliminates “chip traps” for a cleaner operation and less aggravation. This means no more messy part changes or lost small workpieces.
Clamp Faster The QwikSlide movable jaw slides with ease for rapid setup and part changes. Boost operator speed and gain efficiency.
