Otinus Fiber Laser Cutting System Delivers Flexibility for High-Volume Production and Custom Tube Processing!
Wednesday 10 June 2026, 5:39:48 PM
Otinus Corp. has introduced an advanced fiber laser cutting solution designed to meet the growing demand for precision tube and profile processing across a wide range of manufacturing industries. Engineered to handle both high-volume production runs and specialized custom projects, the system provides manufacturers with the flexibility, accuracy, and efficiency required in today’s competitive fabrication environment.
As industries increasingly seek versatile manufacturing equipment capable of handling diverse production requirements, fiber laser technology continues to gain popularity due to its ability to deliver high-speed, high-precision cutting across a variety of materials and geometries. Otinus’ latest tube and pipe laser cutting system is designed to address these needs by offering a comprehensive solution for processing tubes, profiles, and structural sections with different cross-sectional shapes and dimensions.
The machine is capable of processing materials up to six meters in length, making it suitable for applications ranging from standard production components to large structural elements. Its versatility allows manufacturers to efficiently cut a broad range of profiles commonly used in industries such as construction, automotive, aerospace, agricultural equipment, furniture manufacturing, industrial machinery, and metal fabrication.
One of the system’s key strengths is its ability to support both serial production and custom fabrication projects. While many manufacturers require high-speed production of standardized components, there is also increasing demand for one-off prototypes, custom assemblies, and specialized parts. The Otinus fiber laser system is designed to seamlessly accommodate both requirements, allowing businesses to maximize machine utilization while maintaining production flexibility.
At the heart of the machine is an integrated rotary positioning unit that enables fast, accurate, and repeatable material handling throughout the cutting process. This automated positioning capability ensures precise alignment of workpieces, helping manufacturers achieve consistent cutting quality while reducing setup times and minimizing operator intervention.
The rotary system supports a wide variety of material shapes, including round tubes, square tubing, rectangular sections, and specialized profiles. This flexibility allows manufacturers to process different component designs using a single machine platform, reducing the need for multiple dedicated systems and improving overall operational efficiency.
The laser cutter is equipped as standard with a RayTools autofocus cutting head, a widely recognized solution for industrial laser cutting applications. The autofocus functionality automatically adjusts the focal position during operation, helping maintain optimal cutting performance across varying material thicknesses and geometries. This feature contributes to improved cut quality, enhanced productivity, and reduced setup complexity.
For manufacturers working with more challenging materials or requiring exceptionally high levels of precision, Otinus offers an optional Precitec cutting head. Known for its advanced performance capabilities, the Precitec solution delivers enhanced cutting accuracy and increased processing speeds, particularly when working with thicker materials or intricate component designs. This upgrade enables users to tackle demanding projects while maintaining excellent edge quality and production efficiency.
Beyond traditional tube cutting operations, the system can be further enhanced through the addition of an optional 3D cutting head. This capability significantly expands the machine’s functionality by enabling complex cutting operations such as bevel cutting, chamfering, angled cuts, and advanced contour geometries. These features are particularly valuable in industries where components require precise weld preparation, structural assembly features, or customized edge profiles.
The integration of 3D cutting capabilities allows manufacturers to reduce secondary processing operations, improve part accuracy, and streamline overall production workflows. By completing multiple machining requirements in a single setup, companies can lower production costs while accelerating delivery times.
As manufacturing environments continue to evolve toward greater customization, automation, and efficiency, equipment capable of handling both repetitive production tasks and highly specialized projects is becoming increasingly important. Otinus’ fiber laser cutting system addresses these challenges by combining advanced laser technology, automated material positioning, and expandable cutting capabilities into a single versatile platform.
With its ability to process a wide range of tube and profile geometries, support complex cutting operations, and deliver consistent precision, the system offers manufacturers a powerful tool for improving productivity, enhancing flexibility, and meeting the diverse demands of modern metal fabrication.
