ISCAR Expands FEEDMILL End Mill Range with Larger-Diameter Two-Flute Tools for High-Feed Roughing Applications!
Saturday 25 July 2026, 6:50:22 AM
ISCAR has expanded its EFF-S solid-carbide FEEDMILL end mill range with the introduction of larger-diameter two-flute cutters engineered to deliver outstanding high-feed roughing performance across a wide variety of demanding machining applications. Developed to improve chip evacuation, increase tool life, and enhance machining stability, the latest additions to the FEEDMILL family provide manufacturers with a versatile solution for roughing operations involving hardened steels, die and mould materials, stainless steels, titanium, cast iron, and high-temperature alloys.
As manufacturers continue to seek shorter machining cycles and higher productivity, roughing operations have become increasingly critical to overall manufacturing efficiency. High-feed machining strategies allow significantly greater material removal rates while reducing cutting forces, enabling machine tools to remove larger volumes of material without compromising stability. To fully benefit from these strategies, cutting tools must combine robust geometry, effective chip evacuation, and exceptional wear resistance. ISCAR has developed the expanded EFF-S FEEDMILL range to meet these demanding production requirements.
A key feature of the new end mills is their two-flute design, which has been optimised to maximise chip evacuation during aggressive roughing operations. Compared with tools featuring a greater number of flutes, the larger flute spaces provide more room for chips to exit the cutting zone quickly and efficiently. Improved chip evacuation reduces the risk of chip recutting, lowers cutting temperatures, and minimises the potential for tool damage, particularly during deep machining operations or when machining difficult-to-cut materials.
The enhanced chip flow also contributes to greater machining stability by maintaining smoother cutting action and reducing vibration. Stable cutting conditions not only improve surface quality but also extend tool life, allowing manufacturers to maintain consistent production while reducing tooling costs and machine downtime associated with frequent tool changes.
The EFF-S FEEDMILL cutters feature a durable bottom radius geometry designed to strengthen the cutting edge during heavy-duty machining. The reinforced geometry distributes cutting forces more evenly across the tool, improving resistance to chipping and edge failure while enabling aggressive metal removal. This makes the tools particularly well suited for demanding roughing applications where high cutting loads and continuous machining place significant stress on the cutter.
The expanded range has been specifically developed to support a wide variety of machining operations commonly encountered in die and mould manufacturing, one of the industry’s most demanding sectors. Typical applications include slotting, pocketing, helical interpolation, and contour machining to depths of up to three times the tool diameter (3XD). These capabilities allow manufacturers to perform complex roughing operations with fewer tool changes while maintaining high productivity and machining accuracy.
One of the major advantages of the FEEDMILL series is its ability to machine an exceptionally broad range of materials. The tools are suitable for hardened steels up to 65 HRC, enabling manufacturers to machine hardened moulds and dies without requiring extensive secondary operations. They are equally effective when machining widely used tool steels such as P20 and H13, which are commonly employed in injection moulds, die-casting dies, and tooling applications.
Beyond tool steels, the cutters are also designed for cast iron, stainless steel, titanium, and high-temperature alloys. These materials are frequently used in aerospace, automotive, energy, medical, and precision engineering industries, where machining performance directly impacts productivity and component quality. The versatility of the FEEDMILL range allows manufacturers to standardise tooling across multiple materials and applications, simplifying inventory management while improving operational flexibility.
Solid-carbide construction further enhances the performance of the new cutters by providing exceptional rigidity and wear resistance during demanding machining operations. The combination of carbide strength and optimised cutting geometry enables the tools to withstand high cutting forces while maintaining excellent dimensional stability and consistent machining accuracy over extended production runs.
High-feed roughing strategies continue to gain popularity because they allow manufacturers to maximise spindle utilisation, shorten machining cycles, and improve machine efficiency. By reducing radial cutting engagement while increasing feed rates, these strategies generate lower cutting forces and improved tool stability, enabling greater productivity without overloading the machine tool. The expanded EFF-S FEEDMILL range has been developed specifically to support these modern machining techniques while ensuring reliable chip control and long tool life.
The introduction of larger-diameter two-flute cutters reflects ISCAR’s continued commitment to advancing cutting tool technology in response to evolving manufacturing requirements. As manufacturers increasingly machine harder materials, larger workpieces, and more complex geometries, robust roughing tools capable of delivering high productivity and dependable performance have become essential components of efficient production processes.
With the expansion of its EFF-S solid-carbide FEEDMILL range, ISCAR provides manufacturers with a powerful high-feed machining solution that combines superior chip evacuation, durable cutting-edge geometry, broad material compatibility, and exceptional process reliability. The new end mills are designed to help manufacturers increase material removal rates, extend tool life, reduce production costs, and achieve consistently high performance across a diverse range of modern machining applications.
