Dillon Manufacturing Expands Workholding Flexibility with Advanced Collet Pad and Jaw System!
Wednesday 10 June 2026, 3:26:46 PM
Dillon Manufacturing has introduced its new Collet Pads & Jaws system, designed to help machine shops increase workholding versatility, improve machining performance, and maximize the utilization of existing equipment. The solution provides manufacturers with greater flexibility when handling a wide variety of part geometries and materials while reducing setup times and increasing overall productivity.
As manufacturers continue to seek ways to improve efficiency and reduce operational costs, workholding systems play a critical role in achieving consistent machining performance. Dillon’s latest collet pad and jaw technology addresses these challenges by expanding the workholding capabilities of existing chuck systems, allowing shops to tackle a broader range of applications without significant capital investment.
The system is particularly beneficial for job shops and precision manufacturers that regularly process small-diameter components, tube stock, and bar stock. It supports through-hole chucking applications commonly used in Swiss-type machining, making it an effective solution for industries that require high levels of precision and repeatability.
Designed for demanding machining environments, Dillon Collet Pads & Jaws are suitable for a wide range of operations, including precision boring, drilling, tapping, finishing, and high-speed machining. The system can be utilized in the production of medical components, hydraulic fittings, specialty valves, transmission parts, manifolds for high-pressure air systems, crimp assemblies, spools, stems, and numerous other precision-engineered components.
One of the key advantages of the system is its ability to significantly expand a chuck’s workholding range. Traditional workholding setups often require dedicated solutions for different part geometries, resulting in increased setup complexity and additional tooling costs. Dillon’s collet pad top jaw system enables manufacturers to machine a wider variety of parts using the same chuck platform, providing greater flexibility and reducing the need for multiple workholding systems.
At the heart of the solution are precision-ground collet pads that deliver exceptional accuracy and full-contact gripping across the workpiece surface. This design ensures improved holding power and enhanced stability during machining operations. A more secure grip allows operators to perform heavier and more aggressive cutting operations with confidence, ultimately reducing cycle times and improving productivity.
The company offers multiple collet pad configurations, including round, hexagonal, and square options. Manufacturers can also choose between smooth and serrated gripping surfaces to meet specific application requirements. This versatility allows shops to accommodate a broader range of materials and component designs while maintaining high levels of machining accuracy.
A standout feature of the system is the incorporation of Carbinite-coated gripping surfaces. Carbinite is a specialized wear-resistant carbide coating engineered to increase friction and improve workpiece retention. According to Dillon Manufacturing, the coating can effectively double gripping strength while maintaining the same clamping force. This enhanced grip minimizes the risk of part movement during machining, improves surface finish quality, supports more aggressive cutting parameters, and may contribute to extended cutting tool life.
In addition to performance benefits, the system delivers significant advantages in setup efficiency. Traditional workholding changeovers often require replacing an entire chuck assembly, a process that can take several hours and result in valuable machine downtime. With Dillon’s collet pad system, operators only need to change the jaws, enabling setup changes to be completed in minutes.
This rapid changeover capability can dramatically improve machine utilization rates, with some operations potentially achieving up to a 30 percent increase in productive machine time. The ability to quickly switch between different part sizes and geometries provides manufacturers with greater responsiveness, particularly in high-mix, low-volume production environments where frequent setup changes are common.
Dillon Manufacturing also offers a comprehensive range of compatible solutions, including S-Type and Warner & Swasey-style collet pads, W&S solid emergency collet pads, and models designed for Gisholt, Jones & Lamson, and Martin systems. This broad compatibility allows manufacturers to integrate the technology into existing equipment while protecting previous investments in machine tools and workholding systems.
As manufacturers continue to prioritize flexibility, efficiency, and cost-effective production, Dillon’s Collet Pads & Jaws system provides a practical solution for expanding machining capabilities, improving workholding performance, and maximizing productivity without the need for extensive equipment upgrades.
