Dugard Showroom Unveils New ZOPO V8P Machining Centres
Dugard has announced the arrival of three new ZOPO V8P machining centres at its showroom, all…
Dugard has announced the arrival of three new ZOPO V8P machining centres at its showroom, all set to embark on their journey to various production facilities. The Zopo V-Series is gaining popularity as one of the most sought-after vertical machining centres, renowned for its efficiency in moving swiftly into active production environments.
These high-performance machines boast a significant table size of 500 × 1000 mm and travel dimensions of 850 / 500 / 550 mm, with a load capacity of 500 kg. This setup is particularly beneficial for handling heavy and bulky workpieces. The V8P models are equipped with a high-speed direct-drive spindle capable of reaching 12,000 rpm, with an optional upgrade to 15,000 rpm.
The machining centres feature a BBT40 spindle taper and a 24-station automatic tool changer, with an option to expand to 30 stations. Built with high-rigidity hybrid roller-linear-guideways and solid cast iron construction, these machines have been designed for optimal stability and speed through finite-element analysis.
The ZOPO V8P is ideal for producing parts in sectors such as automotive, aerospace, medical, and general subcontract work. Its combination of premium performance and cost-effectiveness makes it a smart investment for both high-mix job shops and volume-driven production lines.
For those interested in a demonstration or securing one of these technologically advanced machines, Dugard encourages potential buyers to contact their sales team.
Dugard continues to support the manufacturing industry with cutting-edge solutions designed to enhance productivity and efficiency in production environments.
