Guhring Medical, brilliant parts from brilliant tools
By Giovanni Albanese
Friday 11 November 2022, 2:01:52 PM
Carbide machine tool specialist Guhring are at AMB 2022 in Germany showcasing their range of products aimed at the medical market. Rainer Stanaker from Guhring explains to MTDCNC’s Gio there are two types of medical products, implants and instruments. Some implants require a shiny brilliant surface finish and if you are machining in metal this is not a problem as the coolant is easily removed when the process is complete. However with plastic medical inserts the coolant or oil will impregnate the part making it unusable. The solution is dry machining, so Guhring have developed a range of incredibly high performance tools to give the surface finish surgeons demand. Guhring offer their customers a full turnkey solution, you send them 3D models and plans and they will provide you with the cutting tools required, together with the processes and systems. Guhring, your one stop shop for tooling.
