Yaskawa Introduces Compass 2 CNC Software to Enhance Machine Tool Performance and Productivity!
Tuesday 14 July 2026, 7:38:26 AM
Yaskawa America Inc. has introduced Compass 2, an advanced CNC software solution developed for its iCube Control platform, offering machine tool builders and manufacturers a powerful combination of intelligent machine control, high-speed motion performance and flexible software customization. Designed primarily for CNC routers, Compass 2 integrates industrial PC capabilities with Yaskawa’s real-time machine controller to deliver faster processing, smoother machining and greater productivity across a wide range of manufacturing applications. The software has been engineered to simplify machine development while providing users with the flexibility to customise both machine functionality and operator interfaces according to specific production requirements.
As manufacturers increasingly demand higher machining speeds, improved accuracy and greater automation, CNC software has become a critical factor in determining machine performance. Beyond simply interpreting G-code, modern CNC systems must optimise toolpaths, coordinate multiple axes, manage machine logic and deliver smooth motion while maintaining tight dimensional tolerances. Compass 2 addresses these requirements by combining the computing power of an industrial PC with the real-time motion and logic control capabilities of Yaskawa’s iC9200 machine controller, creating an integrated solution capable of handling complex machining operations efficiently and reliably.
One of the software’s key strengths is its optimisation for CNC router applications, where high-speed machining and precise motion control are essential for achieving consistent part quality. Compass 2 delivers rapid G-code processing, advanced macro programming capabilities and intelligent path planning designed to maximise machine productivity. By efficiently processing machining instructions and optimising movement between cutting operations, the software enables manufacturers to reduce cycle times while maintaining high levels of precision and repeatability.
The software incorporates advanced block look-ahead technology and high-speed contouring algorithms that continuously analyse upcoming toolpaths before machining begins. These intelligent features allow the CNC controller to anticipate changes in direction, adjust machine motion accordingly and maintain smooth, uninterrupted cutting performance. As a result, manufacturers can sustain higher feed rates while maintaining accurate corner geometries, reducing vibration and producing superior surface finishes. This capability is particularly valuable in applications involving intricate contours, complex profiles and high-speed routing operations where smooth machine movement directly impacts product quality.
To provide machine builders with greater flexibility, Yaskawa includes Compass Designer, a powerful software development environment that allows users to create customised human-machine interfaces (HMIs). Manufacturers can either begin with Yaskawa’s example interface for rapid machine deployment or develop completely customised operator interfaces tailored to specific customer requirements. Built as Windows WPF applications, these custom HMIs function as standalone executable programs while maintaining seamless communication with the iC9200 machine controller. This approach enables machine builders to create unique user experiences that improve operator efficiency while supporting specialised machine functions.
Compass Designer also provides extensive opportunities for machine customisation beyond the operator interface. Machine builders can develop their own custom G-code commands, M-codes and macro programs to support specialised machine operations such as automatic tool changers, probing systems and custom canned machining cycles. This level of programmability allows OEMs to differentiate their machines while meeting the specific needs of customers across various manufacturing industries. The flexibility to create customised machine functions also reduces development time and enables faster deployment of specialised equipment.
The software further supports comprehensive machine integration through compatibility with Yaskawa’s iCube Engineer library and starter project, simplifying PLC integration and overall machine development. Once the Sigma-X servo axes and machine I/O systems have been configured, the CNC platform is fully prepared for machining operations. This streamlined commissioning process reduces engineering effort while allowing manufacturers to bring new machines into production more quickly and efficiently.
By combining advanced motion control, intelligent path planning, flexible programming capabilities and fully customisable operator interfaces, Compass 2 offers machine builders a comprehensive CNC software platform that enhances both machine performance and user experience. The solution enables manufacturers to improve machining accuracy, maximise productivity and simplify machine development while providing the scalability needed to support future automation and digital manufacturing initiatives.
With Compass 2, Yaskawa continues to strengthen its portfolio of advanced CNC control technologies, providing manufacturers with an integrated software solution capable of supporting the evolving demands of modern machining. By delivering faster processing, smoother motion control and extensive customisation capabilities, the platform helps machine builders develop high-performance CNC systems that improve efficiency, reduce development time and deliver superior machining results across a wide range of industrial applications.
