Takumi Showcases U800 Five-Axis Machining Center for High-Precision Manufacturing at IMTS 2026!
Takumi USA is showcasing the latest generation of its U800 five-axis machining center at IMTS 2026, highlighting a machine engineered to deliver exceptional precision, superior surface finishes and high-speed performance for complex machining applications. Designed to meet the stringent requirements of industries such as aerospace, die and mould, and medical manufacturing, the U800 combines a rigid machine structure, advanced thermal compensation, high-speed spindle technology and intelligent automation to provide manufacturers with a reliable solution for producing intricate components with outstanding accuracy and repeatability.
As manufacturers continue to machine increasingly complex components from high-performance materials, the demand for five-axis machining centres capable of delivering both productivity and precision has grown significantly. Components with intricate geometries often require simultaneous multi-axis machining to reduce setup time while maintaining tight tolerances and excellent surface quality. The U800 has been developed to address these requirements by integrating advanced mechanical design with intelligent control technologies, enabling manufacturers to produce high-value parts efficiently in a single setup.
At the heart of the machine is Takumi’s True Gantry design, a rigid double-column construction that provides exceptional structural stability during heavy cutting operations. Unlike conventional machining centre designs, the True Gantry architecture distributes machining forces evenly throughout the machine structure, reducing vibration and improving machining accuracy. Combined with a one-piece casting, the rigid framework allows the U800 to achieve high cutting feed rates while maintaining excellent dimensional stability and superior surface finishes, even when machining demanding materials.
The U800 is equipped with a 20,000 rpm HSK-63A spindle, providing the speed and performance required for precision machining across a wide range of applications. High spindle speeds enable manufacturers to achieve fine surface finishes while reducing machining cycle times, particularly when processing complex moulds, aerospace components and medical parts that demand high-quality surface integrity. The spindle is further enhanced by Takumi’s iSpin III intelligent thermal compensation system, which continuously monitors spindle temperature and automatically compensates for thermal growth caused by prolonged machining or changes in ambient conditions. By maintaining consistent spindle positioning, the system helps preserve machining accuracy throughout extended production cycles.
To further improve precision and simplify machine operation, the U800 incorporates a Renishaw RMP400 high-accuracy probing system. The integrated probe allows operators to perform automated workpiece measurement, setup verification and in-process inspection directly within the machine. This reduces manual setup time, improves process control and ensures greater machining consistency while minimising the risk of dimensional errors.
The machine has also been designed to maximise productivity through enhanced tooling capacity. As standard, the U800 features a 64-station automatic tool changer, allowing manufacturers to accommodate a wide variety of cutting tools for complex machining operations without frequent manual intervention. For applications requiring even greater flexibility, an optional 96-station automatic tool changer is available, enabling extended unattended machining and reducing downtime associated with tool changes.
Takumi has further enhanced machine performance by equipping the U800 with roller-type linear guideways, which provide a larger contact area than conventional ball-type linear ways. This design increases machine rigidity, supports faster axis movements and delivers smoother linear motion, contributing to higher machining accuracy and improved dynamic performance. For rotary motion, the machine utilises contactless magnetic direct drives on both the A and C axes. These direct-drive systems eliminate mechanical backlash, ensuring precise rotary positioning and exceptionally smooth five-axis interpolation. The result is improved contour accuracy and the ability to produce mirror-quality surface finishes on complex components.
Designed to accommodate larger workpieces than many competing machines in its class, the U800 offers a spacious machining envelope capable of handling components with a maximum diameter of 1,150 mm (45.3 inches) and a maximum height of 700 mm (27.6 inches). This generous working capacity makes the machine suitable for manufacturing large moulds, aerospace structural components and other complex precision parts requiring multi-axis machining.
To meet different customer preferences, the U800 is available with either the Heidenhain TNC7 CNC control featuring a 24-inch LCD display or the Siemens Sinumerik One NCU1760 equipped with a 15-inch LCD. Both control systems provide advanced five-axis programming capabilities, high-speed processing and intuitive operator interfaces that support efficient machine operation and digital manufacturing integration.
By combining robust mechanical construction, intelligent thermal management, advanced motion control and high-speed machining capabilities, the Takumi U800 delivers a comprehensive solution for manufacturers seeking superior precision and productivity. At IMTS 2026, the machine demonstrates Takumi’s commitment to developing advanced five-axis machining technologies that help manufacturers achieve exceptional surface finishes, tighter tolerances and greater operational efficiency across the most demanding precision manufacturing applications.
