Dillon Manufacturing full-grip pie jaws deliver stronger clamping and reduced part distortion!
Thursday 26 March 2026, 10:50:40 AM
Dillon Manufacturing has introduced its full-grip pie jaws, designed to provide maximum contact area and reliable clamping performance across a wide range of machining applications. Engineered for strength, precision and versatility, these jaws help manufacturers achieve better grip, improved accuracy and reduced part deformation during operations.
A key advantage of Dillon’s full-grip jaws is their construction from 6061 extruded aluminum bar stock. Unlike cast components, which may contain internal porosity, extruded aluminum offers a denser and more uniform structure. This results in higher strength, improved reliability and enhanced safety during machining operations, particularly in high-speed or high-load environments.
The design of the full-grip jaws focuses on maximizing surface contact with the workpiece. By increasing the contact area, the jaws provide greater friction for drive, ensuring secure clamping while minimizing the risk of slippage. At the same time, this distributed clamping force reduces localized الضغط on the part, helping to prevent distortion—an important factor when machining precision components.
These jaws are especially well-suited for high-speed machining applications, where stability and balance are critical. They also perform effectively in operations such as boring, tapping, drilling and finishing, where consistent clamping force directly impacts dimensional accuracy and surface quality.
Dillon’s full-grip pie jaws are available in diameters up to 28 inches, offering flexibility for a wide range of part sizes. In addition, the jaws can be modified to heights of up to 10 inches and widths that exceed the chuck face diameter, enabling manufacturers to handle larger or more complex workpieces. This adaptability makes them suitable for both standard and customized machining setups.
Beyond aluminum, the jaws are also available in alternative materials including brass, 1018 steel and cast iron. This allows manufacturers to select the most appropriate material based on their specific application requirements, such as strength, wear resistance or compatibility with the workpiece material.
Customization is another important feature of Dillon’s offering. The company provides tailored designs with specialized heights, diameters and configurations to meet unique machining needs. Options such as matching serration locations—positioned perpendicular to the slots—help ensure proper alignment and secure mounting within the chuck system.
In modern manufacturing environments, where precision, repeatability and efficiency are critical, workholding solutions play a vital role in overall process performance. Poor clamping can lead to part distortion, reduced accuracy and increased scrap rates. By contrast, solutions like Dillon’s full-grip pie jaws help maintain consistent part positioning, improve machining stability and enhance overall productivity.
With their robust construction, customizable design and ability to provide uniform clamping force, Dillon Manufacturing’s full-grip jaws offer a reliable solution for manufacturers seeking to improve workholding performance while maintaining high levels of precision and efficiency on the shop floor.
