50% Higher Feed Rates and 60% Longer Tool Life – Guhring’s RT100 Inox Pro Redefines Stainless and Titanium Drilling
Friday 20 June 2025, 8:33:19 AM
Guhring has raised the bar in precision drilling with the launch of the RT100 Inox Pro, a high-performance drill designed specifically for stainless steels and titanium alloys. Engineered to overcome the most demanding machining challenges, the RT100 Inox Pro delivers 50% higher feed rates and 60% longer tool life compared to conventional drills, dramatically improving productivity and cost-efficiency.
EXPLORE GUHRING UK IN A VIDEO WE SHOT RECENTLY
This performance leap is the result of a powerful combination: a new tough carbide grade, a specially developed tool geometry, and a next-generation wear-resistant Perrox coating. The drill’s sickle-shaped cutting edge ensures smooth swarf formation and efficient evacuation, while polished flutes enable rapid chip removal, eliminating built-up edges and maintaining cutting precision—particularly when drilling depths reach up to 7xD.
With a 140-degree point angle and internal coolant channels, the RT100 Inox Pro is engineered for maximum process reliability and longevity. It is available in diameters from 3mm to 20mm in 0.1mm increments, supporting both metric and imperial sizes. Offered in 3xD, 5xD, and 7xD variants, the drill provides flexibility for a wide range of applications—from shallow to deep-hole drilling—without compromising stability or tool life.
  • 3xD version: overall lengths from 62mm to 131mm; flute lengths from 20mm to 79mm
  • 7xD version: overall lengths from 70mm to 244mm; flute lengths from 30mm to 190mm
Further expanding this innovation line, Guhring introduces the Inox Pro fluteless tap, a solution tailored for tapping stainless and austenitic steels where conventional tools fall short. The tap features a synchronized macro and micro geometry with an optimized polygon profile and lubrication-friendly flute design. It’s coated with HiPIMS AICrN, a temperature-resistant and ultra-smooth coating that minimizes wear and delivers exceptional thread quality, even with water-based emulsions.
Together, the RT100 Inox Pro drill and the Inox Pro tap provide a complete high-performance solution for manufacturers aiming to enhance reliability, precision, and productivity in challenging materials.
Watch a youtube video here https://www.youtube.com/watch?v=LFRMvrnVmtQ
To learn how Guhring can transform your machining performance, contact your local Guhring representative today.
