Sharpening specialist VOLLMER will present its 5S campaign: Sharp, Smart, Sustainable, Social, Strong. On Stand 7C50 in Hall 7, visitors can inspect the sharpening machines, services and digital solutions offered.
VOLLMER will be showcasing new tool grinding machines from its VGrind range as well as new products for machining carbide-tipped circular saws. Other highlights will include the VLaser 370 laser machine, the VHybrid 260 grinding and eroding machine and the digital V@dison solutions.
With its grinding, eroding and laser machines as well as automation solutions for operator-free machining, VOLLMER is a full-line supplier for sharpening applications.
With its new 5S campaign, VOLLMER has established five pillars to support its product range- all backed by smart and digital services to ensure maximum sharpness. Thanks to sustainable technologies, VOLLMER plays its part in environmental sustainability.
GrindingHub will also mark the world premiere of three new VGrind machines, suitable for machining carbide tools. These apply the tried-and-tested technology of the VGrind range: They are also based on the innovative double-spindle concept, which enables multi-level machining with its two vertical spindles.
VOLLMER has also added two new machines to its range for grinding circular saw blades. They are ideally suited to machining tooth faces and tooth tops as well as the flanks of carbide-tipped saw teeth with a wide range of geometries. These machines feature intuitive operation, enabling users to learn sharpening processes almost instantly. They can also be combined with the VOLLMER automation solutions to operate them around the clock without manual intervention. Furthermore, the subsidiary Loroch GmbH will also show grinding machines for machining, especially HSS circular saws and HW thin-cut circular saws as well as the TC 720 measuring and documentation system.
The solutions will also be on display with the full-line offered by VOLLMER that will include a wide variety of eroding and laser machines. The company will feature the VLaser 370 laser machine, the VOLLMER QXD 250 eroding machine and the new VHybrid 260 machine for eroding and grinding operations in a single machine.
Maintenance, training and finance are at the heart of the services, and these are increasingly digital and web-based thanks to the V@dison solutions. Software solutions control sharpening machines and automated processes and can increase performance. Smart solutions are also available for evaluating process data or cross-connecting users directly with VOLLMER services. Customers can connect to technicians in real-time via the ‘Visual Support’ V@guide solution, or access machine data, information and a spare parts shop online via a personalised customer portal.
