Unison will be presenting several new technologies at MACH on Stand 630 Hall 6. It will show an all-electric Unison Breeze 16mm (maximum tube diameter) multi-stack tube bending machine, equipped with the company’s Unibend control. There will also be a Unison EvBend 1000, a machine developed to reduce the entry cost to precision rotary draw tube bending by combining manually operated feed, tube rotation and bending force with CNC-controlled braking on the carriage feed, rotation and bend arm axes.
Additionally, there will be the opportunity to get the lowdown on Unison’s newly launched range of Synergy HBM (hybrid, multi-stack) range of machines. Unison offers more than 30 all-electric tube and pipe bending machines for diameters ranging from 4 to 275mm with each model delivering rapid setup, fast tool changes, rigid mechanical design and an all-electric control for right-first-time repeat subcontract work.
Available in 50 and 80mm versions, Unison’s new Synergy hybrid range combines electric and hydraulic operation. Just like Unison Breeze machines, each model benefits from a powerful and rigid mechanical design. As with Breeze models, bend arm, carriage, the plane of bend and carriage side shift are servo-driven, while mandrel, pressure die and clamping systems are hydraulically controlled.
