šŸŽ§Timpson elevates successwith DMU 75 monoBLOCK
Wednesday 19 November 2025, 8:00:00 AM
0:00 / 0:00
Timpson Engineering has recently installed a DMG MORI DMU machining centre with a PH150 automated pallet system. This enables the company to deliver increasingly complex components with unprecedented efficiency.
Built on high-mix, low-batch production specialising in 3 and 4-axis CNC machining, Timpson Engineering recognised the need to expand capabilities as component complexity increased. Established in 2021 as a father-and-son business, Timpson explored 5-axis options, initially considering three-plus-two positioning before investing in full simultaneous 5-axis capability.
ā€œIt did take a lot of thinking. There’s a lot of machines on offer,ā€ Chris Timpson from Timpson Engineering recalls. Nathan Whitaker from DMG MORI’s provided a consultative approach that proved invaluable. Initially considering 3+2 systems, Chris recalls: ā€œWe realised that a machine like the DMU 75 is more affordable than we thought, and with the full simultaneous 5-axis, it was a no brainer.ā€
The DMU 75 monoBLOCK represents what Whitaker describes as ā€œthe best all-rounderā€ in DMG MORI’s 5-axis portfolio. The monoBLOCK series offers exceptional versatility for subcontract operations. As Chris Timpson notes: ā€œYou can do small work on a big machine, but you can’t do big work on a small machine.ā€
Technical Capabilities
Drive Results
Timpson Engineering selected a Siemens control system to maintain consistency with existing equipment. ā€œWe use Siemens in the rest of the workshop, so it was really simple to learn – essentially, it’s the same control with a couple of extras,ā€ Chris Timpson reports.
The machine’s thermal compensation system automatically measures and adjusts for temperature variations, ensuring tight tolerances remain consistent. Chris Timpson describes the improvement: ā€œOn other machines, you program the hole, you machine it, you compensate it. On the next part, you have to compensate it some more. On this machine, it’s ā€˜set and forget’. I’ve programmed one hole at the start of a batch, and maybe 400 holes later, it’s still delivering the exact same size H7 tolerances.ā€
Automation
Maximises Capacity
The integrated PH150 pallet automation system transforms the DMU 75 into a 24-hour production asset. During working hours, operators perform roughing operations whilst actively managing swarf. Once the shift ends, automation runs finishing operations overnight. ā€œWe do the roughing out in a day, so we can manage the swarf. And then the finishing runs overnight,ā€ Timpson explains.
The pallet system provides operational flexibility in high-mix environments. Multiple fixtures remain permanently set up on different pallets, allowing repeat orders with minimal changeover. When discussing completing parts in one operation, Chris notes: ā€œIt gives us a completed part that we’re a lot more confident in. All the errors from your setups are reduced, the part comes off finished.ā€
Quality and Efficiency Gains
Complex parts featuring machined features on nearly every face now complete in two operations versus multiple setups on 3-axis equipment. ā€œThere are machine features in nearly every face on some parts. On a 3-axis machine, that would take quite a while, but it was done on the DMG MORI machine in two ops,ā€ Chris explains.
The machine’s automated deburring capability delivers significant savings. ā€œThe time savings are brilliant. The amount of manual labour you have to do to deburr some of these complex parts is a lot. A couple of minutes in the machine can save half an hour of hand finishing.ā€
Machine Protection Control (MPC) uses sensors to detect potential collisions before they occur, typically resulting in nothing more serious than a broken tool. Application tuning cycles automatically optimise cutting parameters based on real-time feedback, maintaining optimal conditions throughout the cycle.
Support Infrastructure
DMG MORI’s support infrastructure played a crucial role in implementation success. Machine networking enables remote diagnostics, with technicians logging in from Germany to assist with issues. ā€œWe have the machine networked, so someone can log in and support us through the control and operations,ā€ explains Timpson.
For Chris Timpson, the investment has proven transformative: ā€œWe’re delighted. It’s an excellent machine.ā€ The ability to deliver completed parts in single operations, maintain tight tolerances consistently, and operate efficiently in lights-out mode has strengthened the competitive position whilst opening doors to more complex, higher-value work.
