3D engineering solutions provider T3DMC (The 3D Measurement Company Ltd) will launch three new 3D scanning solutions at MACH. Visitors to Hall 19 Stand 639 will be able to see live demonstrations of the all-new SIMSCAN, KSCAN Magic and TrackScan P42.
The new SIMSCAN weighs only 570g and measures only 203 by 80 by 44mm. The SIMSCAN can capture areas of 410 by 400mm at a rate of over 2,000,000 measurements per second. The SIMSCAN is manufactured using aerospace-grade aluminium which makes this 3D scanner very robust, whilst also being very comfortable to hold and easy to use.
Building on the success of the previous KSCAN series, the KSCAN Magic scanner is packed with 41 blue laser lines and delivers scanning speeds of up to 1.6 million measurements per second. The KSCAN Magic has five separate measurement modes in one scanner and this includes built-in photogrammetry.
The TrackScan P42 will also be on show to demonstrate how to capture accurate and highly detailed data without the use of reference markers. The P42 3D scanning system boasts 1.9 million measurements per second. This combined with a large measurement volume of up to 16.5m3 and dual measurement volumes for small and large parts makes the P42 an extremely versatile and capable measurement system.
