Minimal set-up and changeover times for turning
Tuesday 22 March 2022, 8:32:21 PM
Heimatec will introduce its heimatec.Capto™ at MACH in Hall 20 Stand 243. Heimatec is expanding its product range with a further modular tool quick-change system, which increases efficiency and tool changeover times. The heimatec.Capto™ offers wide modularity as well as a variety of change-over inserts for lathes and machining centres.
In addition to a wide range of standard tools with Capto adaptions, the heimatec.Capto™ program also offers a large number of specific tools designed for machine optimisation. The modular quick-change system is characterised by a compact design with a short overall length that allows high cutting speeds and surface quality. The heimatec.Capto™ tool quick-change system is available for Capto sizes C3, C4, C5, C6 and C8.
The company will also show its heimatec.SwissTooling that offers a comprehensive range of static and driven tooling units for many types of Swiss-type lathes. Machining companies can implement heimatec radial drilling and milling heads, woodruff key cutters, multi-spindle adapters, multi-spindle heads and radial drilling heads with maximum speeds of 6,000 to 10,000rpm. In addition, 2, 3 or even 4-spindle radial drilling heads are available as double-spindles.
