Guhring – the standard in deep drilling
Wednesday 14 July 2021, 12:20:42 AM
As a world leader in hole making, Guhring has now published a new deep hole drilling catalogue. The new 250+ page publication is dedicated to the standard deep hole drilling product lines available from the Birmingham-based manufacturer.
With new, expanded and existing deep hole drilling product lines, the new catalogue is crammed with all the latest ‘off-the-shelf’ as standard products. Guhring introduces deep hole drilling lines from 0.9mm to 52mm diameter with overall drill lengths beyond 3m in variants that include solid carbide, brazed gun drills, modular drills, spiral fluted solid carbide and HSS drills plus pilot drills and accessories.
With too many product lines to mention, the highlights of the catalogue include details on the EB100 and EB100M series. As the smallest and most robust of the Guhring lines, the EB100 is available from 0.9 to 16mm diameter with an 80XD that takes the flute length to 580mm. Suitable for most material types, this brazed solid carbide single fluted gun drill is the perfect complement to the EB100M series. The EB100M is a variant for drilling tight tolerances, and it offers an MQL shank. Both drills are complemented by the EB80 and EB80 XXL brazed single fluted gun drills that have been expanded with new forms and coatings added. The ZB80 series for cast-iron drilling has also been expanded with diameter ranges from 6 to 30mm and overall lengths up to 1m for this 2-fluted brazed carbide specialist range.
Already perceived as an excellent performer in flexible deep hole drilling, the Guhring EB800 single fluted gun drills with interchangeable inserts and guide pads have now been expanded yet further with new insert grades, coatings and geometries. With each drill body covering a 0.5mm diameter in the 12 to 52mm scope of the series, Guhring has now introduced expanded drill dimensions with new EB800 insert grades and coatings.
Completing the drilling line-up is the HSS and solid carbide spiral fluted deep hole drills and the pilot drilling tools. Guhring presents a variety of options that include solid carbide and HSS stub-length drills, indexable drills, centre cutting end-mills and piloting end mills.
Guhring has also crammed the new publication with all the accessories and extra equipment that will help you generate your perfect hole. This comprehensive range of additional extras includes everything from drill bushes, steady rest bushes, moulded steady rest bushes, sealing disks and plugs, adjustment screws, torque wrench sets and even drill grinding and re-sharpening equipment.
Guhring has also incorporated a technical section with tables, charts and useful data for maximising your machining performance. This extremely comprehensive section is promoted as an ideal guide for deep hole drilling applications.
