🎧Efficient milling
Milling is a fundamental process that shapes everything from complex aerospace components to critical automotive parts. But despite its ubiquity, successful milling hinges on some careful considerations. How can manufacturers consistently achieve high accuracy, impeccable surface finishes, and cost-effective results? Barry Cahoon, Product Solution Specialist Rotating Indexable—Europe at Sandvik Coromant, offers his advice.
Achieving optimal milling results necessitates selecting cutting tools specifically engineered to meet precise machining requirements. This must consider factors such as cutting geometry, material hardness, and machining strategies. Whether the task involves high-precision shoulder milling, high-speed face milling, or complex multi-axis contouring, the tool’s performance directly influences the efficiency and accuracy of the entire process.
What defines
successful milling?
Precision is paramount for any milling operation to be considered successful. Achieving tight dimensional tolerances and geometric accuracy is essential. Surface finish is another critical factor. A smooth, clean finish is not just an aesthetic requirement but often a functional one. In industries such as aerospace, where components such as turbine blades or compressor casings must meet stringent performance standards, even slight deviations in surface quality can lead to major problems. Efficiency also comes into play. Milling processes need to maximise material removal rates while keeping machining time to a minimum, all without compromising quality.
Then there’s the question of tool life. Manufacturers constantly seek ways to extend tool life, reduce tool changes, minimise downtime, and ultimately cut costs. However, tool life is closely linked to chip control and cutting forces. Poor chip evacuation or excessive force can cause rapid tool wear, reducing efficiency and producing suboptimal results.
Tool selection
With so many variables, selecting the right tool is often the biggest challenge. Different operations — such as shoulder, face, or high-feed milling — demand tools with specific geometries and cutting capabilities.
Accuracy and precision are the foundation of every milling process. From creating flat surfaces to machining 90-degree shoulders or complex contours, precision is non-negotiable. Proper tool path control, optimised cutting parameters, and stable machine dynamics are all essential to ensure that dimensional tolerances are met. Thanks to their true 90-degree shoulder capability, tools like CoroMill® MS60 deliver reliable performance, particularly for shoulder milling.
Efficiency and cost-effectiveness are key considerations in any manufacturing environment. Time saved on machining processes translates directly to reduced costs, making it essential to minimise cycle times without sacrificing quality. In this regard, CoroMill® MH20, specifically designed for lightweight milling, offers excellent performance in operations where high-speed material removal is required. Its insert design reduces cutting forces, allowing for faster feed rates while maintaining tool stability, particularly in deep cavity and pocketing applications. This increases machining speed and extends tool life, reducing the need for frequent tool changes and lowering overall production costs.
Chip control and cutting forces are often underestimated but profoundly impact the milling process. Efficient chip evacuation prevents heat buildup and ensures a clean cut, especially in applications involving deep cavities or pockets. Insufficient chip control can cause chips to re-cut, leading to poor surface finish and faster tool wear. Modern tool geometries are designed to optimise chip flow, reducing the risk of clogging and improving overall tool longevity. CoroMill® MF80 offers smooth chip flow and minimal cutting forces, making it highly reliable for roughing and finishing operations. Its ability to handle various materials and machining conditions enhances versatility and productivity across multiple applications.
Finally, precision and reliability are non-negotiable when selecting tools for demanding materials such as ISO M and ISO S. CoroMill® MS20, Sandvik Coromant’s new 90-degree shoulder milling solution, delivers exceptional edge-line security and dimensional accuracy. This ensures high productivity and consistent results, even in challenging aerospace and oil and gas applications.
Successful milling hinges on a deep understanding of the interplay between tool design, material properties and machining parameters. By carefully selecting tools that are purpose-built for the task at hand — whether that’s shoulder milling with high precision or high-speed face milling for rapid material removal —manufacturers can achieve their goals of improved productivity, lower costs and exceptional part quality. The balance between accuracy, efficiency, tool life and chip control ultimately defines a successful milling operation.
