At MACH, Dugard Machine Tools will be showcasing a raft of new machines – many of which will be receiving their MACH debuts. On Stand 640 in Hall 20, Dugard will be introducing four new machine tools on its stand.
With one of the most diverse portfolios of machines in the UK, Dugard will be introducing the Kitamura MedCenter5AX 5-axis vertical machining centre for fast precise machining. Complementing the MedCenter5AX will be the larger Dugard GTX-620 5-axis machining centre. With vastly different configurations, the two machines will highlight just a small element of the expansive Dugard milling range.
The Kitamura MedCenter5AX 5-axis VMC is an extremely compact and versatile machine. With an X, Y and Z-axis travel of 254 by 330 by 330mm over a 170mm diameter table, the machine incorporates a 30 to 30,000rpm spindle with an HSK-E40 spindle taper that is connected to a 40-tool ATC that can change tools in just 1.5 seconds. Providing a rapid traverse of 60m/min and table rotation of 200rpm on the A and C-axis and a pallet change system, this machine will attract attention at MACH.
For the machining of larger components, Dugard will be introducing the GTX-620 simultaneous 5-axis machining centre. With an X, Y and Z axis of 620 by 520 by 460mm and the capacity to accept workpieces up to 700mm diameter on the table, the GTX-620 complements the smaller Kitamura MedCenter5AX. Available with a FANUC or Siemens 840D CNC control system, spindle power up to 22kW a BT40 spindle taper and a 12,000rpm spindle motor, the GTX-620 is a powerful solution.
The B-axis tilts from -50 to +110 degrees with the C-axis capable of rotating a full 360 degrees to 0.001degree. Dugard can equip the machine with a range of optional extras. The options include linear scales, optical encoders, laser or contact tool length measurement, chip flushing, HSK63 20,000rpm or a 15,000rpm direct-drive spindle and much more. Dugard will also be introducing fixed and sliding head turning centres at MACH.
