When Direct Engineering & Site Services Ltd opened its doors in Sheepbridge, it was a small fabrication shop. Fast-forward 28 years, and the Chesterfield company operates from a 40,000sq/ft premises with five divisions that deliver diverse services to customers throughout the UK and Europe.
Direct Engineering specialises in the installation of material handling equipment, vacuum conveying, and chiller pipework systems. It has evolved from a fabrication company, adding services such as machining. Dugard has supported the company with its exceptional range of machine tools with the latest acquisition being a Dugard SMEC SL 3000LM turning centre.
Ray Woolley from Direct Engineering says: “We started in 1997 as a fabrication company that initially machined on a smaller scale. As time progressed, we saw the need to expand our machining operations as our customers requested more machining services, as well as welding and fabrication. So, we grew on the milling and turning side and invested in CNC machines.”
To accommodate a variety of materials, the versatility of the Dugard SMEC SL3000LM machine is reaping rewards for the Chesterfield manufacturer. Ray continues: “Each material has its challenges and how it cuts, but with a wide listing of materials and types of work, Dugard helped us with a machine breakdown and quickly got us up and running. For that reason, we continued our relationship with Dugard. We’ve had a lot of good productive advice from Dugard on how to deal with this diverse range of materials.”
However, the latest SMEC SL 3000LM was not the first Dugard machine to arrive at the Derbyshire company. Direct Engineering has a range of Dugard machines, including the SMEC PL2500, PL35 and PL45 turning centres. Discussing the purchase of specific options on its machines, such as steady rests and live tooling, Ray says: “Having very capable machines has given us much diversity in what jobs can go on what machines. We can also get finished products from the Dugard machines with the live tooling facility. Previously, these jobs may have gone from a turning centre to a milling operation.”
Actively working to enhance its customer service, Direct Engineering is ISO:9001 and ISO:1090 certified. The company has increased its plant list from one to four Dugard machines that are all installed in a machine shop with a limited floor area. As Ray says: “It’s a compact machining cell. To maximise our space, we spoke to Colin and Eric at Dugard about what machines are the best fit for our company to maximise our output. They’ve given some very constructive advice. This advice enables projects to progress through the machine shop very well, and in an organised manner, so we appreciate all the support we’ve had over the years.”
Looking closer at the Dugard machines the company has acquired, Ray confirms: “We started with the biggest machine first, which we needed for large billet work. We bought the Dugard SMEC PL45LY for this work, which has a large machining capacity. As we slowly phased out older machines, we invested in the SMEC PL2500 and the PL35, which are bigger machines. Then came our most recent addition, the SMEC SL3000. This has a bar feed and steady rest, which ensures we can cover most applications in this machine shop. The Dugard machines with live axial and radial tooling have enabled us to keep jobs on the machines rather than transferring parts to a milling machine.”
Looking at the current workload, Ray adds: “The parts we produce go from small high volume up to your big billet work that can be machined on the Dugard SMEC PL45LY machine. Our parts range from one end of the size scale to the other, and we’ve got the machines here to accommodate that. Additionally, we are machining to tight tolerances on some of the shaft work, especially regarding the concentricity required on parts before finishing.”
