As machining gets more complex and customers expect more for less, the need to simulate, verify and optimise the machining process has never been more evident. This is where VERICUTs connectivity comes in.
VERICUT can directly connect and communicate with multiple sources of software, including CAD/CAM, tool management systems and data from vendors and the cloud. This gives access to the most current information available and ensures that the virtual machine and simulation is as accurate as possible.
Using direct interfaces with all leading CAM systems, VERICUT creates a seamless integration between the CAM system and simulation software, which streamlines data flow, avoids replication, eliminates human error and makes the transfer for multiple setups and operations quick and easy.
As well as reports that can be configured to run automatically after simulation, log files, cutting data and images, VERICUT offers a complete Reviewer file. This is a file that can be opened by any Windows PC or tablet and allows users to view the full simulation. It’s a 3D representation of the simulation that can play forward and backwards while removing and replacing the material. The user can rotate, pan and zoom just like normal VERICUT, and the cut stock can be measured using all the standard X-Caliper tools. Tools such as reviewer and reports allow complete visibility throughout the manufacturing process of how parts should be produced and connects the entire workflow.
