🎧Brother halves cycle times
Monday 27 January 2025, 9:00:00 AM
0:00 / 0:00
In 2023, R&A Engineering won a contract to produce several hundred aluminium parts per month across six variants for assembly into sensors that optimise wind turbine orientation to maximise power output. The job involved tying up a pair of BT 40-taper VMCs, which impacted the Aylesbury-based subcontractor’s ability to do other work. So, the decision was taken to order and transfer production to a 30-taper, high-speed Brother M200X3 VMC with a 16,000rpm spindle.
Delivered in August 2023 by Whitehouse Machine Tools, the Speedio M200X3 5-axis VMC has, on average, halved the time it takes to complete post-anodising milling, drilling and tapping operations on the six components. Therefore, the machine can perform the same work as the two VMCs used previously, which are now free to carry out other work.
Ed Piotrowski, Operations Manager at R&A, said: “We approached a couple of 30-taper VMC suppliers, but Whitehouse was the obvious choice, even though we have never bought a machine from them before. It is a family-run firm like ours and has a similar ethos regarding service, which was obvious when we visited their showroom in Kenilworth for demonstrations.”
“The Brother performs very well. Cycle times are now between one-and-a-half and four minutes, half of what they were before, and the ±0.05mm tolerance is held all day long without any problem. It is an accurate machine.”
Established in 1985 by Ed’s parents, Richard and Alison, and currently employing 18 staff, R&A has grown by 50% since 2021. It has invested £800,000 in machine tools over the past couple of years and is looking to automate production in the turning and milling sections. The rationale is twofold: to take on extra work without compromising existing, long-running contracts; and to be more cost-competitive on the world stage to accelerate the flow of work already being reshored from Asia and elsewhere in increasing quantities.
Ed has some interesting insights into why a subcontractor should invest in a 30-taper VMC. An adage in contract manufacturing is that one never knows what work will come through the door next. Therefore, the wider applicability of a 40-taper machine due to its size and power makes more sense. The first advantage of a nimble milling machine with a smaller diameter tool interface is high-speed production, which translates into greater profitability. Not only does the elevated spindle speed combined with up to 30m/min cutting feed rate provide generous metal removal rates, but idle times are lower due to 50m/min rapids in the X, Y, and Z axes.
A less well-known benefit is the vastly lower power consumption of 30-taper machines. Ed advised that the M200X3 draws less than 10kVA, versus typically 50kVA for a 40-taper VMC or perhaps even more if it is an old machine. Energy bills are therefore lower and, as is the case at the Aylesbury facility, if a factory is close to its power supply limit, the lower kVA rating is a godsend.
Reviewing the characteristics of the respective BT spindle machines, Ed observes that while power and rigidity are higher in a 40-taper VMC, modern, smaller-taper counterparts such as the Brother have a reasonably well-specified spindle motor with good torque, even in the medium to high-speed range. The drive motors are also consistent with robust machining, and face-and-taper-contact tool retention assists further, as in R&A’s case.
“Although machining of light alloys is the province of this type of machine, using modern CAM software to create intelligent cycles involving light depths of cut and high-speed contouring means that tough and difficult-to-machine metals can also be tackled.”
The M200X3 has a further advantage for OEMs and subcontractors alike. It is equipped with a torque motor to drive the rotary table, allowing a component to be indexed and rotated at up to 2,000rpm so it can be machined with a static turning tool in the spindle. Completing this second operation in-cycle without the need to re-fixture the part in a lathe raises accuracy and productivity.
The mill-turn capacity in a small footprint holds much potential on the shop floor at R&A. Take, for example, the wind turbine sensor job for which the machine was purchased. All six parts undergo turn-milling on a lathe before being sent out for anodising. The Brother must only remove the insulative anodic layer in certain areas to provide electrical conductivity. With the latter machine’s turning capability, all parts could be completely machined. Richard and Ed are actively considering this possibility, which would require automated component handling to be retrofitted.
In addition to seizing opportunities in the renewable energy sector, R&A is also taking advantage of growth in vehicle electrification. Two aluminium parts have already been produced on the Brother VMC for the latter sector. One is an EV engine terminal block, which is milled, drilled and tapped in a 20-minute cycle. Another engine part has been transferred to the M200X3 from a 40-taper machine, with the part now machined in eight minutes rather than 12, again leading to more competitiveness, shorter lead times and more overall capacity on the shop floor.
Ed is already planning the next job for the Brother. Water purification work accounts for about one-third of the subcontractor’s turnover. One of the parts machined from Ertacetal, an electrically conductive plastic, is currently turned and milled in four set-ups on three other machine tools. On the Brother it will come off complete after two set-ups.
