Allied Machine and Engineering now announces the arrival of their new high-penetration drilling system, the T-A Pro™. The T-A Pro drill combines material-specific insert geometries, a re-designed drill body and a proprietary through-coolant system to allow penetration rates that are claimed to run at speeds up to 30% faster than other high-performance drills on the market.
The coolant outlets are designed to direct maximum flow to the cutting edge, providing quick heat extraction. Material-specific insert geometries produce impressive chip formation and the drill body incorporates straight flutes that are designed for maximum coolant flow and rigidity. The T-A Pro drill offers machine shops a spade drill in diameters from 11.1mm to 47.8mm and is ideal for holes ranging in stub, 3XD, 5XD, 7XD, 10XD, 12XD, and 15XD depths. The drill is available in both metric and imperial shanks with flat and cylindrical variants. The carbide insert geometries will initially cater for the following ISO material classes – Steel (P) with the AM300 coating, Cast iron (K) with the TiAlN coating and non-ferrous materials (N) with the TiCN coating.
