The Tungaloy T9200 CVD Series of insert grades for steel turning has now been extended with the arrival of the new T9225 insert grade, which will build upon the earlier successes of the impressive T9125 grade.
The new T9225 insert grade brings an exceptional combination of unparalleled wear resistance and edge toughness of all P25 grades available on the market to every steel turning application. These properties of T9225 are attained by three primary technologies, including:
Extremely wear resistant Al2O3coating in a thick and uniformly aligned layer
Ultra-hard ceramics for the outermost layer
PremiumTec – Tungaloy’s exclusive post surface treatment technology
These make T9225 a versatile steel turning grade effective in a wide range of applications, ensuring long tool life and stable performance for improved productivity.
In combination with proven T9215 grade, T9225 joins the T9200 series to cover various steel turning needs.
The range of T9225 includes the -TSF, -TM, and -TH chipbreakers: the first choice for steel turning in standard ISO inserts as well as successful ISO-EcoTurn inserts. A total of 349 inserts are introduced in T9225 to cover a wide range of applications.
- At a Glance:
- Thick and uniformed crystal growth Al2O3layer for impressive wear resistance
- Ultra-hard ceramic layer with 1.5x hardness for improved wear resistance
- PremiumTec – post surface treatment technology for stable machining
- Total of 349 items to be added
