The TurnTen-Feed turning inserts from Tungaloy is an economical, 10-cornered insert, which ensures high machining efficiency.
Features include:
Available in 2 types of holders: HD type for large depths of cut and HF type for high feed turning
Maximum 7 mm (0.276″) depth of cut, or maximum 2.0 mm (0.079″) feed per rev is attainable
Economical 10-cornered, double-sided, M-class insert
Achieves outstanding cost efficiency over standard ISO inserts
New MNW style chipbreaker
Features protrusions on the rake face to facilitate smooth chip control, while achieving high crater wear resistance
Dovetail clamping
Ensures secure insert retention while promoting smooth chip flow thanks to the integration of lever lock and dovetail clamping methods.
Flat Wiper
Built in the cutting edge to achieve superior machining surface at higher feed rates
