New Quickgrind End Mill is a Demon for Surface Finish Applications
Achieving a super-fine surface finish is a challenging proposition that has now been simplified by Quickgrind with the arrival of its new Demon multi-flute end mill. Capable of delivering impressive surface finishes on a wide range of components and materials, the unique geometry is combined with 8 flutes to generate the precise recipe for highly accurate machining of any surface requiring a superb finish.
Developed and manufactured in the UK for profile milling of steel and hardened steel, the Demon is suitable for use on materials up to 60HRc and can also be applied to stainless steel, cast iron and high temperature alloys. The impressive new Demon is manufactured from sub-micron grade carbide and is coated with Quickgrind’s MX coating technology, which enhances tool life and longevity for the end user. The square end series has a centre cutting geometry and a variable flute design that permits increased speeds and feeds. The combination of the tool geometry, carbide grade and coating combine to increase productivity and metal removal rates.
From a dimension perspective, the Demon is available in a complete range of diameters, flute lengths and overall lengths and even corner radii to suite the exact needs of the client. Furthermore, the coating technology aids chip flow and gives a high resistance to wear, which instils customer confidence in the performance parameters and longevity of the new Demon Series. The surface finish capabilities of the Demon make it the first choice end mill line for all your finish milling operations. For more details, contact Tewkesbury based Quickgrind.
