DMG MORI Introduces MATRIS WPH Flexible Automation System for Workpiece and Pallet Handling!
DMG MORI Canada has expanded its automation portfolio with the launch of the MATRIS WPH, a flexible automation system designed to streamline the handling of both workpieces and pallets in modern CNC machining environments. Developed to meet the evolving demands of manufacturers facing fluctuating production schedules, smaller batch sizes, and increasing product variety, the new solution offers a scalable and adaptable approach to shopfloor automation while improving machine utilisation and manufacturing efficiency.
As manufacturers continue to embrace Industry 4.0 and smart factory practices, automation has become an essential component of competitive production. Traditional automation systems are often optimised for high-volume production, but today’s manufacturers increasingly require solutions capable of handling mixed production runs, customised components, and rapidly changing customer demands. The MATRIS WPH has been developed to address these challenges by providing a highly flexible automation platform that can seamlessly manage both individual workpieces and pallets within a single manufacturing system.
The automation solution enables workpieces and pallets to be automatically loaded, stored, and transferred throughout the machining process, reducing manual intervention while ensuring a continuous flow of production. By integrating automated material handling directly with CNC machining centres, manufacturers can minimise idle machine time, increase spindle utilisation, and improve overall productivity. The system also allows operators to prepare new jobs while machines continue running, supporting longer unattended production periods and maximising equipment efficiency.
One of the key advantages of the MATRIS WPH is its ability to adapt to changing production requirements. Whether manufacturers are producing small batches, high-mix components, or medium-volume production runs, the system offers the flexibility needed to respond quickly to varying customer orders without extensive production reconfiguration. This makes it particularly suitable for subcontract manufacturers, precision engineering companies, and businesses serving industries where production volumes frequently change.
DMG MORI has designed the MATRIS WPH to integrate with several of its advanced CNC machining centres, providing customers with a versatile automation solution that can be incorporated into existing production environments. The system is compatible with the company’s 5-axis machining centres, including the DMU 50 3rd Generation, DMU 60 eVo 2nd Generation, and DMC 65 monoBLOCK 2nd Generation and DMC 75 monoBLOCK 2nd Generation. In addition, it supports a range of vertical machining centres from the NVX and CMX V series, enabling manufacturers to automate multiple machine platforms using a common automation concept.
The MATRIS WPH is available in two configurations to accommodate different manufacturing requirements. The MATRIS WPH 70 is designed for smaller components and supports transfer weights of up to 35 kilograms, while accommodating pallet sizes of up to 400 x 400 mm. This configuration is well suited for precision machining operations requiring compact automation with high flexibility.
For manufacturers producing larger components, the MATRIS WPH 210 provides increased handling capacity, supporting transfer weights of up to 135 kilograms and pallet dimensions of 500 x 500 mm. The larger system enables businesses to automate heavier machining applications while maintaining the same level of flexibility for changing production schedules and varying workpiece sizes.
By combining automated storage, intelligent material handling, and seamless machine integration, the MATRIS WPH supports manufacturers seeking to improve productivity without sacrificing operational flexibility. Automated handling not only reduces manual labour but also minimises the risk of handling errors, improves workplace safety, and ensures consistent positioning of workpieces throughout the machining process. These benefits contribute to improved machining accuracy, higher repeatability, and enhanced overall manufacturing quality.
The introduction of the MATRIS WPH reflects the growing industry trend towards modular and scalable automation solutions that can evolve alongside changing manufacturing requirements. As labour shortages, shorter product lifecycles, and increasing demand for customised production continue to reshape global manufacturing, flexible automation systems are becoming critical investments for companies looking to enhance competitiveness and maximise the return on their machining equipment.
With the launch of the MATRIS WPH, DMG MORI further strengthens its portfolio of smart manufacturing solutions, offering customers an automation platform capable of supporting high-productivity machining across a broad range of applications. By delivering greater flexibility, efficient workpiece management, and seamless integration with advanced CNC machining centres, the new system enables manufacturers to build more agile, automated, and future-ready production environments.
