Launch of ER HP Collet Chucks sets new standard for high-speed milling
Wednesday 27 May 2026, 11:20:23 AM
Engineered for high-speed milling and 5-axis machining, Seco® has enhanced the ER HP Collet Chuck range. Now with a finely balanced, rigid design, the ER HP delivers smoother finishes, longer tool life, and unmatched reliability.
Tool clamping for demanding applications
The new ER HP Collet Chuck is designed to address the challenges of modern machining where tool slippage, vibration, and unreliable clamping can lead to costly downtime and wasted material. With exceptional run-out accuracy and a robust, symmetrical build, the ER HP ensures consistent results, reduced tooling costs, and faster cycle times. Its high clamping force and secure grip provide process security even during heavy-duty operations, while the intuitive roller key system makes setup quick, safe, and accessible for every team member.
Effortless implementation
Implementing the ER HP Collet Chuck is quick, safe, and straightforward. Unlike complex toolholder systems that require specialized training or risky setups, the ER HP uses a simple roller key for installation making changeovers fast and minimizing downtime. “Our ER HP Collet Chuck is all about giving manufacturers the confidence to push their processes further without sacrificing precision or reliability. By combining fine balancing, high clamping force, and easy implementation, we’re helping our customers achieve smoother finishes, longer tool life, and greater sustainability in their operations,” says Yves Heitz, Global Product Manager for Machine Solutions.
