Guhring UK Introduces RF 100 AL Milling Cutter to Boost Productivity in Aluminium Machining
By Tom Skubala
When machining aluminium, non-ferrous metals and plastics, tooling performance can have a major impact on productivity, cycle times and tool life on the shop floor. Recognising this, Guhring UK has introduced the RF 100 AL solid carbide milling cutter, a tool specifically engineered to maximise performance in these materials.
Developed with aluminium machining in mind, the RF 100 AL is designed to deliver significant gains in efficiency and reliability for manufacturers working with lightweight materials.
Performance testing highlights the benefits the tool can bring to modern machining operations, including:
- Up to 30% increase in machining performance
- 59% reduction in machining time
- 54% longer tool life
A key feature of the RF 100 AL is its geometry, which has been optimised for efficient chip evacuation. This helps prevent chip build-up while maintaining stable cutting conditions, enabling manufacturers to achieve excellent dimensional accuracy and surface finish, even in demanding applications.
The cutter is available in diameters from 1 mm to 20 mm, with options for corner chamfers and corner radii from R0.1 to R4 mm, giving manufacturers the flexibility to apply the tool across a wide range of aluminium machining operations.
With advancements like the RF 100 AL, Guhring continues to demonstrate how innovative tooling design can drive higher productivity, reduced cycle times and improved process reliability, helping manufacturers stay competitive in modern production environments.
