AP Series 7000-14000mm
Tuesday 17 February 2026
Supplier Information
AP Series 7000-14000mm by pietro-carnaghi
AP Series Double Column Design – Large Vertical Lathes:
The AP model features a double-column structure, specifically designed for machining large parts with diameters of up to 14 meters (45.9 feet).
The machine’s structure is built as a unified formation, with the columns mounted to the table base, housing the main spindle and gearbox. All components are assembled to create a robust framework that ensures maximum stability and rigidity, allowing the machine to withstand even the most demanding cutting conditions.
On the front side of the crossrail, two horizontal sliding guides support the vertical ram saddle in its horizontal movement through hydrostatic pockets. The distance between the upper and lower guideways is optimised to maximise cutting performance.
All structural components of the machine are designed using finite element analysis (FEM) methodology, and the main frames undergo thermal stabilisation and specialised treatment processes to enhance durability and precision.
Technology information
  AP 70 T/TM AP 80 T/TM AP 90 T/TM AP 100 T/TM AP 120 T/TM AP 130 T/TM AP 140 T/TM
Max. turning diameter (mm) 7000 8000 9000 10000 12000 13000 14000
Table diameter (mm) 6000 6500 8000 8000 8000 10000 10000
Standard weight (t) 200 200 200 200 200 350 350
Max. allowable weight (t) 250 250 350 350 350 500 500
Standard RPM (RPM) 60 60 50 50 50 35 35
Turning power (kw) 120 – (180) – (300)
Turning height: fixed crossrail 1500
Turning height: movable crossrail 3000 – 3500 – 4000 – 4500 – 5000 – 6000 – 7000 – 8000
Ram section (mm) (400 x 400) – (500 x 500) – (600 x 600)
Ram stroke Z axis (mm) (2000) – (2500) – 3000 – 3500 – 4000
Milling power (kw) 60 / 71 / 100
Max RPM (RPM) 2500 – 3000 – (6000)
Rapid feeds X-Z-axes (mm/min) 15000
View on supplier site
