RB100
Monday 16 February 2026
Supplier Information
RB100 by balance-systems
Manual balancing machine
Features
  • The RB100 is a universal horizontal balancing machine provided with hard bearings support. It is capable of balancing on two planes (dynamic) or on a single plane (static) a wide range of cylindrical rotors, shafts, spindles, etc. weighting between 2 and 100 kilos (4.41 lb and 220.46 lb).
  • Operating interface by industrial PC with touch screen.
  • The correction of the unbalances is carried out manually and it is performed by an operator through material addition or removal.
  • High level of flexibility and quick changeover.
Advantages
  • High measuring precision
  • High balancing precision
  • Quick changeover
  • User friendly
Technology information
Max rotor weight 100 Kg (220.46 lb)
Max rotor diameter ( workable ) 550 mm (21.65 in)
Max diameter driven by belt 180 mm (7.09 in)
Diameter of rotors journals 8-80 mm (0.31-3.15 in)
Controlled by Industrial PC
Drive systems Loop belt
Measuring precision 0.1 gmm/kg max (0.04 oz.in/lb)
Power supply 110-230V 50/60Hz
Machine dimensions (LxWxH) 1.465 x 1.270 x 1.333 mm
(57.68 x 50 x 52.48 in)
Machine weight 700 Kg (1,543.24 lb)
View on supplier site
