SG12S
Monday 16 February 2026
Supplier Information
SG12S by mitsubishi-electric
SG-S Series
The rock-solid machine base of the SG-Series is your assurance of precision and durability. The choice of high-class components ensures the long-term reliability of the machine system.
The simplicity of the control and the programming itself is a hallmark of EDM machines by Mitsubishi Electric. Allowing the operator to focus on the essential, i.e., the proper planning of the various eroding tasks. The operator is also assisted by the intelligent control strategy with integrated job planning and an efficient evaluation of a wide range of operating data, including actual job costing.
The standard equipment of the SG-S rounds off the picture. A fire extinguishing system and C-axis with zero-point clamping system are part of the machine’s standard equipment. Additional useful features enable you to tailor the configuration to your individual requirements.
Advantages include:
- Travel: 400 / 300 / 300 mm
- Workpiece dimensions: 900 x 650 x 350 mm
Technology information
MACHINE |
UNIT |
SG8S |
SG12S |
SG28S |
Travel (X / Y / Z) |
mm |
300 / 250 / 250 |
400 / 300 / 300 |
650 / 450 / 400 |
Max. workpiece dimensions (W x D x H) |
mm |
770 x 490 x 200 |
900 x 650 x 350 |
1050 x 760 x 350 |
Max. workpiece weight |
kg |
550 |
1000 |
2000 |
Max. electrode weight |
kg |
25 |
50 |
200 |
Table dimensions (W x D) |
mm |
500 x 350 |
700 x 500 |
850 x 600 |
Table layout |
Steel / 3 T-slots |
Steel / 5 slots |
Daylight (table – C-axis with EROWA chuck) |
mm |
150–400 |
200–500 |
175–575 |
Max. dielectric filling level (measured from worktable surface) |
250 |
400 |
400 |
Overall dimensions with tool changer (W x D x H) |
mm |
1530 [2170] x 2070 x 2140 |
1725 [2315] x 2200 x 2420 |
2620 x 2600 x 2745 |
Machine weight |
kg |
2000 |
3500 |
5800 |
Mains voltage |
3-phase 400 V/AC, 50/60 Hz |
