SC-450L
Monday 16 February 2026
Supplier Information
SC-450L by nakamura-tome
IMPORTANT NOTE: this machine as standard, is configured as Tailstock only – with option as a Twin Spindle.
 1520mm Maximum Turning length. Ø 810mm Max Swing Diameter
  • 1520mm Max. Turning length
  • Ø 520mm Maximum Workpiece Swing Diameter
  • NC servo driven Tailstock
  • Massive 45 Degree slant bed for maximum rigidity
  • 30/22kW. 856/627N.m Wide-Range motor for powerful cuts
  • Quicker ‘Non-lift’ turret indexing to cut idle time
  • Box type slides and rigid turret for high accuracy
  • Bar capacity 80mm standard.
  • Dodecagonal 12 station turret
Technology information
General
Machine height 2,184.9mm
Floor space (Length) 5,050mm
Floor space (Width) 2164.8mm
Machine weight 9,000kg
Capacity
Max. turning diameter 480mm
Max. turning length 1,520mm
Distance between center 1,752mm
Bar capacity 80mm / 90mm
Chuck size 305mm (12”)
View on supplier site
