| Built-in Automation – Compact Loader
Monday 16 February 2026
Supplier Information
| Built-in Automation – Compact Loader by nakamura-tome
The compact loader from Nakamura-Tome. Built in automation – the space-saving multi-functional transport system.
The Compact Loader, developed with an emphasis on space-saving, is a loading/unloading system built into the machine. A machine’s height remains the same even after being combined with the Compact Loader, which has the advantage of being less affected by the height limitations of factory ceilings. * The Compact Loader is available for WY-100II, WY-150, NTY³-100 and MX-100.
*The image shown in the gallery, is a combined palletising stocker “HAKO-BEI” as an option.
The servo type is now on stage!
The Compact Loader servo, featuring a servo-driven vertical-axis hand, is now available! The servo type offers improved travel speed and positioning accuracy compared to the conventional type. In addition, it allows users to specify teaching points, making setups even more convenient. The Compact Loader servo can be controlled from its dedicated screen. *The Compact Loader servo is available for the MX-100 only.
Note: this is an automation product only and does not include the machine.
Technology information
DESCRIPTION
Unit
MX-100
WY-100II / NTY3-100
WY-150
Compact loader servo
Standard
Axis extension (op.)
Standard
Z axis travel
mm
2,580
1,955
2,105
2,105
2,255
Workpiece size
 Diameter
mm
Ø20 ~ 130
Ø32 ~ 100
Ø32 ~ 100
 Length
mm
20 ~ 110
20 ~ 100
20 ~ 100
 Weight
kg
3.0 x 2
3.0 x 2
3.0 x 2
View on supplier site
