PL-C Plasma Cutting Machine
Friday 13 February 2026
Supplier Information
PL-C Plasma Cutting Machine by durma
Durma PL-C Plasma Cutting Machine
Durma PL-C (Compact) Series Plasma Cutting Machine has a modular frame. Modular frames are welded, and stress relief is performed after welding to ensure quality and accuracy. High-quality and precise plasma cutting is possible with double-sided synchronized gap-free planetary reducers that offer high precision. High positioning speed, acceleration, and automatic torch height control ensure the best cutting quality for your manufacturing needs. The tables are fragmented and divided for the effective evacuation of smoke that might occur during the cutting processes. Manual and automatic bevel cutting, drilling station, and oxygen cutting heads are some of the available optional features. We as Durma know that you have differing needs, and we provide precise solutions to your manufacturing problems with our innovative and dedicated team.
What Are the Advantages of the PL-C Plasma Cutting Machine?
Durma has redefined its plasma cutting technology with PL-C series. The PL-C Series is manufactured as a true precision tool for plasma cutting. Our high-performance plasma machines are designed to cut a wide range of mild steel, stainless steel and aluminum. They offer:
- Precise Cutting,
- High Durability,
- Energy Efficiency,
- Low energy consumption.
Durma PL-C offers better, faster and more precise cuts. It has a strong and rigid body structure. The PLC Plasma Cutting machine is a durable machine, and it will be by your side for long and productive years. It is a plasma that you can count on. “Reliability and durability” that what makes a the Durma PL-C Plasma Cutting Machine
PLC Plasma cutting machines are reliable sources of plasma cuttings when it comes to higher levels of material thickness. Hypertherm cutting head and AURORA plasma software ensure precise and quality cuts. The AURORA software enables users to enhance plasma with extensive specifications and capabilities. Depending on material and thickness, cut quality and cutting speed it can offer you the appropriate solutions for your tasks.
It has a sensitive, precise Hypertherm cutting head. Moreover, it has the Durma designed and copyrighted AURORA software control unit. The Hypertherm power supply options for different sheet thicknesses. Furthermore, Electrical Panel and Durma Filter that creates a safer working environment. It offers sensitive solutions at high material thickness. PLC is environmentally friendly and energy efficient.
Technology information
MODEL |
Unit |
PL-C 1530 |
PL-C 2040 |
PL-C 2060 |
PL-C 20120 |
PL-C 25120 |
PL-C 30120 |
A – Machine installation length |
mm |
10000 |
11000 |
13000 |
19500 |
19500 |
19700 |
B – Machine installation width |
mm |
6500 |
7700 |
7700 |
7700 |
8200 |
8700 |
C – Part cutting area width |
mm |
1580 |
2080 |
2080 |
2080 |
2580 |
3080 |
D – Part cutting area length |
mm |
3100 |
4100 |
6100 |
12100 |
12100 |
12100 |
E – Machine width |
mm |
2500 |
3000 |
3000 |
3000 |
3500 |
4000 |
F – Machine length |
mm |
4240 |
5240 |
7240 |
13240 |
13240 |
13240 |
G – Distance between machine & power supply |
mm |
1500 |
1500 |
1500 |
1500 |
1500 |
1500 |
H – Filter height |
mm |
2200 |
2200 |
2200 |
2200 |
2200 |
2200 |
I – Machine length with filter |
mm |
9444 |
10424 |
12424 |
19044 |
19044 |
19422 |
J – Table height |
mm |
700 |
700 |
700 |
700 |
700 |
700 |
K – Z axis stroke |
mm |
220 |
220 |
220 |
220 |
220 |
220 |
Weight without filter |
Kg |
3000 |
4500 |
6000 |
11500 |
13000 |
15000 |
