DMK3
Friday 13 February 2026
Supplier Information
DMK3 by balance-systems
Semi-automatic balancing machine
Features
  • Semi-automatic balancing machine for small rotors weighing between 0.05 kg to 0.5 kg (0.11 and 1.10 lb).
  • The material removal is carried out in a completely automatic way on two planes (dynamic).
  • The unbalance is corrected by removing material on the lateral rings as an outcome of radial drilling.
  • Manual loading/unloading.
Advantages
  • High measuring precision
  • High balancing precision.
  • User friendly.
  • Quick and precise changeover by preset mechanical stops.
Technology information
Minimum rotor weight: 0.05 kg (0,11 lb)
Maximum rotor weight: 0.5 kg (1,10 lb)
Rotor OD: 8-40 mm (0,31-1,57 in)
Controlled by: Industrial PC
Machine cycle time: 40 s (measuring, two plane drilling, audit)
Measuring precision: 0.1 gmm/kg (0,04 oz.in/lb)
Balancing method: Radial drilling
Power supply: 120-240 V 50/60 Hz
Machine dimensions (LxWxH): 950 x 1700 x 1900 mm (37,40 x 66,93 x 74,80 in)
View on supplier site
