DC12iMT
Friday 13 February 2026
Supplier Information
DC12iMT by axile
The DC12iMT is the most robust VMC in AXILE’s arsenal, perfectly suited for handling larger, lengthy workpieces. With a 1200 mm diameter built-in table and 2.5 tonnes maximum weight capacity, the DC12iMT is able to accommodate large and heavy 5ax components, while the 2,200 x 1,200 mm machine bed will take on board long and complex parts common in the aerospace, power generation, and die and mould industries. Its double-column bridge construction allows for greater rigidity, as well as greater control over thermal deformation. As a result, the DC12iMT is capable of deep cuts and complex contouring while maintaining utmost precision.
The DC12iMT is equipped with the ART™ intelligent monitoring system (hardware & software). Which enables the adoption of automation and optimises manufacturing productivity through real-time machining data, achieving sustainability in all aspects of business operations.
A snapshot of the AXILE DC12iMT:
Combines both milling and turning in one machine, greatly increasing operational flexibility
- By reducing set-up times and potential clamping errors, the DC12MT can efficiently machine a wider variety of parts, especially cylindrical components
Laser measurement updated for turning tool applications
ART™ monitoring system (hardware & software)
Massive bridge supported on a one-piece base casting
Machine body made of high-quality cast iron
3-guided Y-axis carriage to ensure speed and stability
Extremely rigid 4-guided Z-axis Box-in-Box designed RAM
Torque motor driven B (spindle) and C (table) axis
Large tool magazines as standard
Various pallet changer solutions as option
Technology information
MODEL |
UNIT |
DC12iMT |
STANDARD LINEAR AXES |
X axis |
mm |
2200 |
Y axis |
mm |
1400 |
Z axis |
mm |
1000 |
STANDARD ROTARY AXIS |
Built-in rotary table diameter |
mm |
Ø 1200 |
Full machine table |
mm |
2200 x 1200 |
Table load |
kg |
2500 |
B axis driven system (spindle head) |
Swivel +/- 110° |
Torque motor |
C axis driven system (rotary table) |
Rotary 360° |
Torque motor |
STANDARD |
Maximum Feedrate |
m/min |
36 |
Lubrication type |
Grease |
STANDARD SPINDLE |
Driven system |
Built in |
Maximum speed |
rpm |
20,000 |
Power S1/S6 (40%) |
kW |
60/73.1 |
Torque S1/S6 (40%) |
Nm |
119.4/145.4 |
Interface |
HSK-T63 or HSK-T100 as an option |
Bearing lubricant |
Oil air |
Water chiller ±0.2 degree |
STD |
STANDARD |
Magazine capacity STD |
Tools |
90 |
Smart tool load station |
STD |
ROTARY TABLE |
Maximum table rotation speed |
rpm |
800 |
Power |
kW |
S1 40.8 |
Torque |
S1 3000 Nm, S6-40% 3960 N |
