DMK4-2A-A
Wednesday 11 February 2026
Supplier Information
DMK4-2A-A by balance-systems
Semi-automatic balancing machine
Features
- Semi-automatic balancing machine, specifically developed for balancing rotors for asynchronous motors and for brushless motors and similar rotating parts, in a completely automatic way on two planes (dynamic). The unbalance is corrected by removing material as an outcome of axial drilling.
- It is composed of: one measuring unit, two drilling units (one for each balancing plane) and a rotary table with pneumatic pliers for parts manipulation (from measuring unit to drilling units and vice versa).
- Operator interface by industrial PC.
- High level of flexibility and quick changeover.
Advantages
- Automatic set-up
- High level of repeatability and precision of the unbalance measuring
- Diagnostic and preventive maintenance program
- Quick changeover
- High level of reliability
- User friendly
Technology information
| Max rotor weight | 3 kg (6,61 lb) |
| Rotor diameter: | 30-70 mm (1,18-2,76 in) |
| Stack lamination height: | 20-80 mm (0,79-3,15 in) |
| Cycle time: | < 20 s (plus operator’s handling time) |
| Controlled by: | Industrial PC |
| Measuring precision: | 0.1 gmm/kg (0,04 oz.in/lb) |
| Balancing method: | Axial drilling |
| Power supply: | 380-480 V three-phase 50/60 Hz |
| Machine dimensions (LxWxH): | 1700 x 1800 x 2300 mm (66,93 x 70,87 x 90,55 in) |
