BVK7-5-3A
Wednesday 11 February 2026
Supplier Information
BVK7-5-3A by balance-systems
Automatic balancing machine for HVAC armatures
Features
  • Fully automatic balancing machine, specifically developed for balancing rotors of brushless motors and similar rotating parts, in a completely automatic way, on two planes (dynamic).
  • It is composed of: a measuring unit and a milling unit for left and right planes. The parts manipulation is performed by an embedded anthropomorphic robot equipped with double gripper.
  • The unbalances are automatically corrected by removing material by radial milling on the outer diameter of the rotor.
  • It can be implemented in any type of production lines (pallet, step, by loop, etc.).
  • High level of flexibility and quick production changeover.
Advantages
  • Automatic set-up
  • High level of repeatability and precision of the unbalance measuring
  • Diagnostic and preventive maintenance program
  • Quick changeover
  • High level of reliability
  • User friendly
Technology information
Max disc diameter: 90 mm (3.54 in)
Max disc height: 35 mm (1.38 in)
Max disc weight: 340 g (0.75 lb)
Max machine cycle time: 26 s
Balancing method: External radial milling
Balancing speed: Programmable
Max sensibility: 0,5 gmm/kg
Productivity: Cmk >= 1,33
Controlled by: Industrial PC
Power: 6 kVa
Power supply: 400 V / 50 Hz / 25 A
Machine weight: 2500 kg (5511.56 lb)
Machine dimensions: 2300x4118x2600 mm
(90.55×162.13×102.36 in)
View on supplier site
