16 SERIES
Wednesday 11 February 2026
Supplier Information
16 SERIES by chiron
The development of the new CHIRON FZ/DZ16 was determined by your requirements: High precision, dynamics and best surface quality for increasingly complex workpieces. Result of this intensive Dialogue with the market is a fundamentally new machine platform with mobile gantry design. Advantage for you: Outstanding productivity, highest precision and maximum flexibility are no longer a contradiction.
CHIRON FZ16 S
The single-spindle FZ16 S five axis is designed for special precision requirements in 5-axis machining. At the same time, the machining center shines with optimum values regarding dynamics and thus ensures highest productivity. In short: More parts at highest precision.
CHIRON DZ16 W
The double spindle DZ16 W with workpiece changing device for loading and unloading during machining is the specialist for larger quantities. With even greater dynamics, the machining center produces complex parts with unprecedented precision. In short: Highly precise parts at maximum productivity.
Highly flexible – due to the modular building block principle:
  • Mobile gantry design
  • Small footprint even with a large number of tools
  • Mineral casting machine bed, inherently stiff and vibration-damping
  • High static and dynamic stiffness
  • Excellent thermal stability
  • Highly productive motor spindles
  • Rotary axes with torque direct drive
  • Actively cooled drive components
  • Ideal chip flow through hanging cradle and steeply sloping walls
  • Loading and unloading of tools during machining
  • Context-sensitive and intuitive TouchLine operating system
  • Condition monitoring at the control panel via IO-Link and ProfiNet
  • Service-friendly accessibility to all components
Technology information
Travel X-Y-Z
660-660-400 mm
Power, max.
61 kW
Spindle distance DZ with two spindles
320 mm
Spindle speed, max. up to
20.000 min-1
Chip-to-chip time from
from 2,5 s
Axis acceleration, max. X-Y-Z
15-13-18 m/s2
Rapid feed, max.
75 m/min
Number of tools, max.
162 or 2 x 80
Tool taper
HSK A-63 / SK 40 / HSK T-63
Tool weight, max.
10,00 kg
Tool diameter, max.
160 mm
Tool length, max.
450 mm
Automatic workpiece change from
3,50 s
View on supplier site
