12 Series
Wednesday 11 February 2026
Supplier Information
12 Series by chiron
Fast, compact single and multi-spindle precision machining centres.
The CHIRON 12 series machining centres are among the best machine tools of their class in terms of speed, compact construction and versatility of use. Numerous configuration and equipment options provide the ideal solution for any job. These machining centres can be supplied with single, double, four-spindle or millturn configuration.
Your advantage
  • Workpiece production at the lowest cost per piece
  • The smallest tolerances
  • Excellent surface quality
Technology information
Travel X-Y-Z up to 550-400-425 mm
Spindle power up to 40 kW
Spindle speed up to 40.000 rpm
Axis acceleration up to 2 g
Rapid feed rate up to 75 m/min
Chip-to-chip time approx. 1.9 s
Number of tools max. 177
Tool taper ISO/CAT 30 / ISO/CAT 40 / HSK 40 / HSK 50 / HSK 63
View on supplier site
