Used Cincom A20-VIIPL 7 Axis CNC Sliding Headstock Lathe
Saturday 17 January 2026
Supplier Information
The Used Cincom A20-VIIPL is a versatile, high-performance CNC sliding head lathe engineered for precision and productivity. Key flexibility, this model accommodates both guide bush and non-guide bush modes, ideal for a wide range of part lengths. With up to 7 axes, 2 spindles, and live tooling capabilities, the A20-VIIPL excels in complex, multi-process machining in a single setup, reducing cycle times and boosting throughput. Robust construction ensures excellent rigidity and stability, while the Mitsubishi M800 control system delivers user-friendly programming and advanced operational support. This machine is particularly suited for small-diameter, high-precision work, common in sectors like medical, automotive, and electronics. Whether you’re scaling up production or seeking a reliable addition to your CNC line up, the A20-VIIPL offers exceptional accuracy, repeatability, and value.
