Walter Surface Technologies’ XtraCut XX Sanding Discs Offer Unmatched Efficiency and Durability!
Walter Surface Technologies has introduced its XtraCut XX sanding discs, designed to provide high cutting efficiency and extended durability across a wide range of materials. Engineered for metalworkers, the XtraCut XX is especially effective in removing stock from alloys, ensuring consistent results throughout its lifespan.
One of the key innovations of the XtraCut XX sanding disc is its use of triangular-shaped ceramic grains. These grains are strategically designed to maximize pressure at each contact point, significantly improving cutting efficiency. This unique design allows users to reduce operation time without the need to apply excessive pressure, making the sanding process more comfortable and less strenuous.
In addition to its superior cutting performance, the XtraCut XX is built for longevity. The disc’s exclusive top-size cooling agent works in tandem with the ceramic grains to maintain peak cutting power. The cooling agent effectively minimizes heat buildup during use, which helps prevent overheating and discoloration, ultimately contributing to a smoother and higher-quality surface finish. This is particularly beneficial when working with challenging alloys like stainless steel and high carbon steel, where heat buildup can compromise the finish.
The durability of the XtraCut XX is further enhanced by V-Strong Backing Technology. This innovative feature includes eight vulcanized fiber layers, which reinforce the disc and allow it to withstand the toughest working conditions. The combination of the V-Strong technology and cooling agent minimizes wear and tear, leading to fewer disc changeovers and more uninterrupted work time. This reduction in maintenance time increases overall productivity and reduces downtime for metalworkers.
Antoine Guay, product manager of finishing products at Walter, explains, “XtraCut XX is designed to give metalworkers the best of both worlds: unmatched stock removal and extreme durability. It’s the ideal choice for working with steel, stainless steel, and hard alloys, delivering both high efficiency and a guaranteed cost savings.”
With its advanced design, the XtraCut XX is well-suited for use in demanding applications where both speed and quality are essential. It represents Walter Surface Technologies’ commitment to providing cutting-edge solutions that improve efficiency and enhance the user experience in metalworking and industrial operations.
