Sponsored
  • Breaking
    OUR NEW WEBSITE IS NOW LIVE IN SOFT LAUNCH! WE’RE USING THE CHRISTMAS BREAK TO PUT THE FINISHING TOUCHES ON AN EXCITING NEW PLATFORM SET TO BECOME THE WORLD’S LEADING NEWS CHANNEL FOR MACHINING AND MANUFACTURING. FULL LAUNCH: JANUARY 1ST, 2026.
CNC Heavy Duty Oil Country Lathe (32” Bed)
Thursday 27 March 2025
Supplier Information
CNC Heavy Duty Oil Country Lathe is a famous product line for oil & gas fielding and metal industry. It could be big bore lathe of double chucks at both sides of the headstock, or it could have large swing for big workpiece. It could be applied to oil pipes, big steel rollers, large diameter flanges, long shafts of ships, etc. Besides, for better workpiece clamping, we have rotary quill option on tailstocks.
Description  \  ModelSOH1200SOH1400SOH1600
Swing over bed1190 mm1385 mm1580 mm
Swing over cross slide 740 mm940 mm1140 mm
Bed width800mm (32”) (1000mm with auxiliary guideway)
Distance between centers2000~10000mm (80”~400”) (bed casted in one piece)
Spindle boreØ156mm (6”) / Ø230mm (9”) / Ø260mm (10”) / Ø310mm (12”) / Ø360mm (14”) / Ø535mm (21”)
Spindle noseA2-15 (6”) /  A2-15 (9”) / A2-15 (10”) / A2-20 (12”) / A2-20 (14”) / A2-28 (21”)
Spindle speeds (4 Steps) 6-800 / 4-600 / 4-600 / 3-400 / 3-400 / 2-300 rpm (Chucks are NOT Considered)
Spindle motorS1: 30KW (37KW opt.)
Axes TransmissionX: Ø50 ball screw
Z-axis : Ø80 ball screw (DBC≤5M); Rack and Pinion (DBC≥6M)
Rapid TraversX-axis : 5 m/min , Z-axis : 5 m/min
Max, x-axis travel800mm
Max, z-axis travel1750~14750 mm
Tailstock spindle travel/Quill300mm / Ø200 (Std.) or Ø290 Rotary Quill (Opt.)
Tailstock spindle taperMT#7
Controller FAGOR 8055iFANUC 0i-TFSIEMENS 828D
X-axis servo motorFKM 66α22i1FK7101
Servo motor output ※4.9 KW4.0 KW4.29 KW
Z-axis servo motorFKM 66α22i1FK7103
Servo motor output ※4.9 KW4.0 KW4.87 KW
Coolant pump motor0.7KW (50Hz) / 1KW (60Hz)
※ THE SPECIFICATIONS ARE SUBJECT TO CHANGE WITHOUT PRIOR NOTICE.
32”STANDARD ACCESSORIES32”OPTIONAL ACCESSORIES
CNC controller: FANUC, FAGOR or SIEMENS3-Jaw Chuck
AC spindle motor (22KW)4-Jaw Chuck
Auto lubrication systemFace Plate
Coolant systemHydraulic Chuck
Spindle oil chillerPneumatic Chuck
Electric cabinet air conditionerDouble Chuck System
2-door type splash guardSteady Rest
Chip conveyorFollow Rest
Work lightHeavy Duty Steady Rest (2-point type)
Spindle sleeve and dead center (for spindle bore ≦ 9″)Hydraulic or Electric Milling Device
Tailstock centerHydraulic Spindle Orientation (5 degree resolution)
Leveling bolts & padsBoring Device
Tool box with oiler, spare fuse, paint & toolsHydraulic 4-way Tool Post
Operation & service manualHydraulic V8 Turret
 Hydraulic V12 Turret (for TNC-1200 and above)
 Hydraulic Tailstock
 C-axis Control
 Power Turret
 Full Guarding
    Upcoming Events
    See what’s coming up and join us on the road.
    26 January – 6 February 2026
    26 Jan – 6 Feb | Pfronten Open House
    From January 26 to February 6, 2026, DMG MORI welcomes visitors to the Pfronten Open House, set against the impressive backdrop of the Bavarian Alps. The event offers expanded space for innovation, dialogue, and hands-on experience with the latest manufacturing technologies. Attendees can explore cutting-edge solutions ranging from customized machine concepts for diverse production requirements to highly automated MX solutions with seamless process integration. New technologies on display include gun drilling, holistic 5-axis machining, and advanced process integration combining turning, milling, grinding, gearing, and ultrasonic solutions. Scalable automation systems and practical knowledge transfer are also key focuses, supported by the
    EU | DMG MORI Pfronte…, Pfronten
    Find Out More
    3–5 February 2026
    3 – 5 February | NORTEC | Hamburg
    Production. Innovation. Future.As a trade fair for production, NORTEC in Hamburg offers a platform for the industry every two years. The focus is on machine tools and manufacturing systems, precision tools, measuring and testing technology, robotics and automation, software and IT solutions, components, assemblies, accessories, operating resources and consumables, logistics and operating equipment as well as services. With numerous national and international exhibiting companies, NORTEC covers all stages of the metalworking value chain. For local production companies, but also for guests from all over Germany and neighboring European countries, it has been a must-attend event for over 30 years. For
    EU | Messeplatz 1, Hamburg
    Find Out More
    9–10 December 2025
    9 – 10 December | Okuma | Charlotte
    Experience the Possibilities Time is ticking to see firsthand how Okuma machines and automation technologies transform manufacturing. At the Okuma Machine & Automation Fair, our machines and technologies are available for full display and demonstration. See for yourself what our innovations can do for you.
    NA | Charlotte
    Find Out More
    3 December 2025
    NEW WEBINAR! Desoutter Tools’ Demeter: Real-time Assembly Intelligence – Detect. Predict. Act.
    Every second on the line counts. A delayed decision, a hidden defect, or a missed alert can mean lost output and mounting costs. That’s why manufacturers are turning to data-driven control, using real-time data to act before problems escalate. Join this webinar to discover how Desoutter Tools’ DeMeter turns raw assembly data into live dashboards, predictive alerts, immediate actions, and trend-based recommendations. In this 45-minute session, you’ll learn how to: ✅ Achieve instant visibility – See tightening results, alerts, and KPIs in real time from any device ✅ Harness smart diagnostics – Automatically detect bottlenecks, top stop causes, and underperforming
    UK | Desoutter Webina…, Hemel Hempstead
    Find Out More
