Hurco VC500i 5-AXIS CANTILEVER MACHINING CENTER Ex Stock
The 5-Axis cantilever design supports a wide range of parts and allows you to use standard length tooling due to the B-axis configuration. The full +110° / -110° B-axis motion provides superb undercut capability.
X, Y, Z Axis Travel20.5 x 17.7 x 15.8 in (520 x 450 x 400 mm)
Spindle Nose to Table5.9 in min / 21.7 in max (150 mm min/ 550 mm max)
Table Diameter19.7 in (500 mm)
Max. Weight on Table550 lbs (250 kg)
B Axis Motion-110°/+110°
C Axis Motion360°
T-Slot Size3.9 in (100 mm)
SPINDLEMax. Spindle Speed12000 rpm
Spindle Power (peak)17.4 hp @ 1,500 rpm (13 kW @ 1,500 rpm)
Spindle Torque (peak)61 ft. lbs @ 1,500 rpm (82.7 Nm @ 1,500 rpm)
